[email protected] ~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 03eb:8a03 Atmel Corp.
Bus 001 Device 005: ID 1bcf:2987 Sunplus Innovation Technology Inc.
Bus 001 Device 004: ID 8087:0a2a Intel Corp.
Bus 001 Device 003: ID 03f0:5c11 Hewlett-Packard PhotoSmart C4200 Printer series
Bus 001 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
[email protected] ~ $ hp-check
Saving output in log file: /home/geoffrey/hp-check.log
HP Linux Imaging and Printing System (ver. 3.17.10)
Dependency/Version Check Utility ver. 15.1
Copyright (c) 2001-15 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more detailsSaving output in log file: /home/geoffrey/hp-check.log
under certain conditions. See COPYING file for more details.
Note: hp-check can be run in three modes:
1. Compile-time check mode (-c or --compile): Use this mode before compiling the HPLIP
supplied tarball (.tar.gz or .run) to determine if the proper dependencies are
installed to successfully compile HPLIP.
2. Run-time check mode (-r or --run): Use this mode to determine if a distro supplied
package (.deb, .rpm, etc) or an already built HPLIP supplied tarball has the proper
dependencies installed to successfully run.
3. Both compile- and run-time check mode (-b or --both) (Default): This mode will
check both of the above cases (both compile- and run-time dependencies).
Check types:
a. EXTERNALDEP - External Dependencies
b. GENERALDEP - General Dependencies (required both at compile and run time)
c. COMPILEDEP - Compile time Dependencies
d. [All are run-time checks]
PYEXT SCANCONF QUEUES PERMISSION tatus Types:
OK
MISSING - Missing Dependency or Permission or Plug-in
INCOMPAT - Incompatible dependency-version or Plugin-version
warning: 12-18.04 version is not supported. Using 12-17.04 versions dependencies to verify and install...
| SYSTEM INFO |
Kernel: 4.15.0-45-generic #48-Ubuntu SMP Tue Jan 29 16:28:13 UTC 2019 GNU/Linux
Host: Robert
Proc: 4.15.0-45-generic #48-Ubuntu SMP Tue Jan 29 16:28:13 UTC 2019 GNU/LinuxHPLIP-Version: HPLIP 3.17.10
HPLIP-Home: /usr/share/hplip
warning: HPLIP-Installation: Auto installation is not supported for 12 distro 18.04 version
Current contents of '/etc/hp/hplip.conf' file:
# hplip.conf. Generated from hplip.conf.in by configure.
[hplip]
version=3.17.10
[dirs]
home=/usr/share/hplip
run=/var/run
ppd=/usr/share/ppd/hplip/HP
ppdbase=/usr/share/ppd/hplip
doc=/usr/share/doc/hplip
html=/usr/share/doc/hplip-doc
icon=no
cupsbackend=/usr/lib/cups/backend
cupsfilter=/usr/lib/cups/filter
drv=/usr/share/cups/drv
bin=/usr/bin
apparmor=/etc/apparmor.d
# Following values are determined at configure time and cannot be changed.
[configure]
network-build=yes
libusb01-build=no
pp-build=yes
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
hpijs-install=yes
foomatic-drv-install=yes
foomatic-ppd-install=yes
foomatic-rip-hplip-install=no
hpcups-install=yes
cups-drv-install=yes
cups-ppd-install=no
internal-tag=3.17.10
restricted-build=no
ui-toolkit=qt5
qt3=no
qt4=no
qt5=yes
Distribution: 12 18.04
Bitness: 64 bit
| HPLIP CONFIGURATION |
There's lots more to come. No mmore space.
