Author Topic: What are your 'must have applications/software'?  (Read 1410 times)
Offline Prachi
« on: February 25, 2019, 04:59:47 am »
I searched this sub and I saw a post that was about a year and figured maybe it is appropriate to get a more current consensus on the topic.
Used Linux way back when. Was my main OS for a period of time. Then I switched back to Windows. However, I've recently began using Linux again as my daily driver OS.  free netflix tech news android 9
What do you consider must have applications? Aside from the apps that come w/ the distro I use, I've installed Anacona, VS Code, Atom, and Sublime on my box software.
What software do you download/install immediately after setting up your workstation?
« Last Edit: February 28, 2019, 04:46:50 am by Prachi »
