Author Topic: Sticky Notes not working after upgrade  (Read 2318 times)
Offline Tramlink
  • Is the mist clearing
« on: March 11, 2019, 02:58:13 pm »
Mint 18.3 cinnamon 64bit - I upgraded from version 18.2 and when I booted this morning "Sticky Notes" failed to start.
I was asked to check if I had the latest version which I do only updated this month. https://cinnamon-spices.linuxmint.com/applets/view/194
 No one had reported the same problem with mint18.3 with this taskbar app.
I was also told to check the system log but I can not find it.
Any help would be appreciated.
Re: Sticky Notes not working after upgrade
« Reply #1 on: March 11, 2019, 09:04:45 pm »
You may be better off asking on the Mint forum Tramlink .. I know sod all about these Cinnamon "spices" applets and how they work.
Offline Tramlink
« Reply #2 on: April 09, 2019, 09:52:23 am »
Did not find out any info on Mint No one had reported the same problem with mint18.3 with this taskbar app (not a desktop Cinnamon app).
I am using another app (KNotes) but have to remember to start it each morning.
I put it in the list of programs that start on boot but I still have to open it and select open all notes.
« Last Edit: April 09, 2019, 10:07:28 am by Tramlink »
« Reply #3 on: April 09, 2019, 01:53:14 pm »
Instead of knotes (which I gather relies on the 'restore session' function of KDE) in Cinnamon, maybe instead try indicator-stickynotes.
You can get it for Mint 18 (which is based on Ubuntu 16.04) by direct downloading this file:-
https://launchpad.net/~umang/+archive/ubuntu/indicator-stickynotes/+files/indicator-stickynotes_1.0.0-0~ppa1_all.deb
and double clicking it to install.
Info on it can be found here
https://www.maketecheasier.com/stick-notes-app-ubuntu/
but probably not best to install it with their method as I'm not sure how adding Ubuntu PPA's works in Mint
To UNINSTALL:-
sudo apt-get remove --purge indicator-stickynotes
« Last Edit: April 09, 2019, 02:01:31 pm by Mark Greaves (PCNetSpec) »
Offline Tramlink
« Reply #4 on: April 10, 2019, 10:11:43 am »
Thanks I will give it a try.
« Reply #5 on: April 10, 2019, 02:58:00 pm »
Let me know how you get on.
It works for me in Peppermint 9, so I'd assume it'll work in Mint .. but it is an assumption ;)
Offline Zorba61
« Reply #6 on: April 11, 2019, 11:13:15 am »
Wondering why OP hasn't updated/upgrade to Mint Cinnamon 19.1 Tessa ? Knotes works no problem
« Last Edit: April 11, 2019, 11:23:53 am by Zorba61 »
« Reply #7 on: April 12, 2019, 04:01:06 pm »
Knotes works on his Mint 18 .. but the notes aren't auto opened on login, he has to manually open them.
Offline Zorba61
« Reply #8 on: April 13, 2019, 06:57:19 am »
Oops...... :-[
Anyway just added knotes to start up in Mint 19.1 and it worked,on start up there was knotes open on desktop hope this helps. :-\
« Last Edit: April 13, 2019, 07:10:52 am by Zorba61 »
« Reply #9 on: April 13, 2019, 10:52:04 am »
Handy to know .. thanks :)
Offline Tramlink
Re: Sticky Notes not working after upgrade (resolved)
« Reply #10 on: April 16, 2019, 01:49:06 pm »
indicator-stickynotes working OK so will mark it resolved.
Only recently upgraded so will stick where I am for now.
Thanks to all.
