Author Topic: LIBRE OFFICE why no upgrade (resolved)  (Read 2955 times)
Offline Tramlink
  • Is the mist clearing
« on: April 16, 2019, 02:08:02 pm »
I am using mint 18.3  I have Libre Office 5.1.6.2 installed.
A friend told me that there is now a version 6 of Libre Office.  I was wondering why my version is not being upgraded.
Is it possible to install the newer version directly?
Thank you for your comments in advance.
« Last Edit: May 14, 2019, 02:42:59 pm by Mark Greaves (PCNetSpec) »
Offline dannybombastic
Re: LIBRE OFFICE why no upgrade
« Reply #1 on: April 16, 2019, 04:42:28 pm »
https://snapcraft.io/libreoffice
Try with snap
Sent from my SM-G960F using Tapatalk
Offline Tramlink
« Reply #2 on: April 16, 2019, 10:05:19 pm »
what is snap? can it be trusted.
« Reply #3 on: April 16, 2019, 10:13:15 pm »
universal linux package
Is trusted - snap install package name
Tri it i don't know if is already in your distro
Offline Rich J
  • Still a Linux Luvvie!
« Reply #4 on: April 17, 2019, 08:42:34 am »
Hi - in my experience Mint can take a while to update any aspect due to it's policy of ensuring stability and compatibility.  Newer versions of software can - and do - screw with your system if installed from ppa's so be aware of that and research thoroughly before you go down that route.
I found this - https://askubuntu.com/questions/132837/how-do-i-install-the-latest-stable-version-of-libreoffice
and this - https://askubuntu.com/questions/178052/will-12-04-get-libreoffice-3-6-and-later/178247#178247
which may be of some help?
Do you have a particular need to update it?  Chances are you wouldn't really notice any difference apart from cosmetically.  Anyway, be careful!
HTH
Rich
Offline Tramlink
« Reply #5 on: April 17, 2019, 01:12:55 pm »
Thanks for your input.  Each new version has better MS Office integration.
All our clients even the Mac users use MS Office and there can be issues opening files.
I would like to be able to ditch using MS Office for external communications but LO just not 100% reliable.
Offline Rich J
« Reply #6 on: April 17, 2019, 05:41:52 pm »
Hmmm...... I send various documents to colleagues on Windows using Libre and save in the appropriate format (.doc, .docx, xls etc) and that seems to work ok? At least they haven't come back to me saying they can't read 'em.   ;)
Offline Tramlink
« Reply #7 on: April 18, 2019, 04:27:39 pm »
Word documents without complex settings maybe OK but open an office 365 power point presentation and it can take hours to make it useable in L.O.
So I am hoping that L.O. 6 is an improvement.
Thanks for your comments.
« Reply #8 on: April 18, 2019, 05:12:39 pm »
Run:
sudo add-apt-repository ppa:libreoffice/ppa
sudo apt-get upgrade
you should then be on LO 6.2.2
Offline Tramlink
Re: LIBRE OFFICE why no upgrade (resolved)
« Reply #9 on: May 14, 2019, 01:19:01 pm »
Thanks for that working fine big improvement.
« Reply #10 on: May 14, 2019, 02:43:29 pm »
No problem Tramlink, glad I could help :)
Something else I do is copy all the TTF fonts that come with Office across to Linux .. it can often help with keeping document formatting more consistent.
« Last Edit: May 14, 2019, 02:50:13 pm by Mark Greaves (PCNetSpec) »
Offline Tramlink
« Reply #11 on: May 19, 2019, 11:41:51 am »
Hi how do you copy all the TTF fonts that come with Office across to Linux?
Offline Rich J
« Reply #12 on: May 20, 2019, 08:35:45 am »
Could this be it?  Menu/Synaptic Package Manager/Search "ttf-mscorefonts-installer" gives all Ms fonts.  Apply, then agree to the EULA and you're done.  ;)
Rich
« Reply #13 on: May 20, 2019, 10:16:50 pm »
Can't remember .. Windows will have copied them to (I think)
c:\windows\fonts
or something like that .. just copy them all
Place them in:-
/usr/share/fonts/windows-fonts
(create that directory if necessary)
Then run:
sudo fc-cache -fv
and ya done.
Offline Tramlink
« Reply #14 on: May 26, 2019, 02:30:31 pm »
Thanks.
