Author Topic: [SOLVED] Terminal commands  (Read 796 times)
Offline pooky2483
« on: May 25, 2019, 01:38:43 pm »
I am going to create a dual boot of Kubuntu 16.04 & 18.04 and would like to have an almost identical setup and would like to install the same terminal commands I have in the already installed Kubuntu 16.04, such as 'alien' which is not a standard command.
How can I list all the available commands in terminal?
« Last Edit: May 26, 2019, 01:51:37 pm by pooky2483 »
Re: Terminal commands
« Reply #1 on: May 25, 2019, 07:44:14 pm »
compgen -c | sort
« Last Edit: May 25, 2019, 08:15:00 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #2 on: May 26, 2019, 01:50:45 pm »
Thanks Mark.
I never knew that there were so many terminal commands, including extra ones installed afterwards.
