Author Topic: peppermintos.com  (Read 2179 times)
Offline donwatson
  • Getting older
peppermintos.com
« on: May 27, 2019, 10:40:07 am »
Is there a problem at peppermint hq ??
I can't seem to connect to their site ??
thanks Don W
Novatech build
External 2TiB HD
Offline BkS
  • BkS Media Founder
    • BkS Media
Re: peppermintos.com
« Reply #1 on: May 27, 2019, 04:02:57 pm »
Hi Don,
The website is up, maybe try again?  :)
« Reply #2 on: May 27, 2019, 07:41:45 pm »
Yeah it was down for a while this morning .. back up now :)
Offline donwatson
  • Getting older
« Reply #3 on: May 28, 2019, 09:30:12 am »
Thanks Guys
Novatech build
External 2TiB HD
