Author Topic: stop Opera update  (Read 1196 times)
Offline Zorba61
stop Opera update
« on: May 28, 2019, 03:03:58 pm »
Can somebody guide me on how to stop Opera v 60.0 from updating automatically. (Mint 19 ) In windows I think I had to rename the auto update exe file .
Re: stop Opera update
« Reply #1 on: June 03, 2019, 02:57:15 pm »
If you look in
sudo xed /etc/apt/sources.list.d/opera-stable.list
you'll see a line like
deb https://deb.opera.com/opera-stable/ stable non-free #Opera Browser (final releases)
just comment it out, so it reads
## deb https://deb.opera.com/opera-stable/ stable non-free #Opera Browser (final releases)
and save the file.
The problem with this is Opera's VPN is known to sometimes stop working when they release a new version .. so if that's what you use it for.....
« Last Edit: June 03, 2019, 03:23:18 pm by Mark Greaves (PCNetSpec) »
Offline Zorba61
« Reply #2 on: June 03, 2019, 06:34:40 pm »
Thanks for answer Mark I don't use Opera for it's vpn I have a separate one.
