Author Topic: password  (Read 834 times)
Offline fergalhedge
password
« on: June 17, 2019, 07:16:26 pm »
I am unable to access Linux mint because it no longer accepts the password. It does not come back with an error (invalid) so what I input is correct but Linux does not start up. I cannot get into anything to fix the problem, I am having to use windows to send this message, thankfully I have retained a dual boot option.
Advise on this problem would be most welcome, thanks
Re: password
« Reply #1 on: June 17, 2019, 08:18:46 pm »
At the login screen hit Ctrl+Alt+F2, are you able to log on in text mode ?
If you run:
df -h
are any of the partitions full ?
If you can log on in text mode, do you get any error if you run:
sudo service lightdm restart
