Author Topic: lightburn  (Read 1010 times)
Offline donwatson
  • Getting older
lightburn
« on: June 17, 2019, 08:06:30 pm »
I would like to install lightburn on my linux computer, it comes with the following info.
Linux Installation
1. Open a terminal and run the following command:
sudo adduser $USER dialout && sudo adduser $USER tty
2. IMPORTANT! Log out and log back in (this refreshes the permissions we just added)
3. Download the Linux 64-bit version
4. Extract the folder wherever you want Lightburn to exist
5. Double click AppRun inside your Lightburn folder
Is this ok to install ?? I don't like to install anything and then come back here to get un-install advice when it doesn't work, or should I just try and see what happens ??
Don W
Novatech build
External 2TiB HD
Re: lightburn
« Reply #1 on: June 17, 2019, 08:25:10 pm »
Looks like it doesn't need to be "installed" as much as it's just run from the extracted folder.
So yeah try it .. getting rid is theoretically as simple as deleting the extracted folder.
Offline donwatson
  • Getting older
Re: lightburn
« Reply #2 on: June 18, 2019, 09:48:30 am »
Thanks Mark
Novatech build
External 2TiB HD
