Author Topic: Network manager icon missing in Ubuntu 18.04  (Read 1206 times)
« on: July 11, 2019, 01:24:16 pm »
ASUSTeK P6-P5G41E running Ubuntu 18.04
This machine doesn’t have a wireless card so before donating it I bought a USB wireless adapter (Bonest USB 3.0 ) as it mentioned Linux in the blurb.  I ignored the installation disk and plugged it in with no response from the system, which surprised me.  Indeed, the network manager told me that no dongle was detected.
Next I tried installing the Linux software from the disk but the extract command resulted in a message that I didn’t have sufficient privileges to do the extraction.  So I abandoned that to return the dongle to Amazon.
At this point I noticed that the wireless manager icon had disappeared from the tray at top right.  Hmm!  I plugged in a very old, spare USB wireless adapter which connected me immediately, but still no icon.
Looking on-line for possible solutions, I tried the following with no success:
keith@asus:~$ sudo service network-manager stop
keith@asus:~$ sudo rm /var/lib/NetworkManager/NetworkManager.state
keith@asus:~$ sudo service network-manager start
keith@asus:~$
keith@asus:~$ killall unity-panel-service
unity-panel-service: no process found
keith@asus:~$
keith@asus:~$ sudo apt-get install indicator-applet-complete
   Reading package lists... Done
   Building dependency tree
   indicator-applet-complete is already the newest version (12.10.2+17.10.20170425-   0ubuntu1).
   indicator-applet-complete set to manually installed.
keith@asus:~$
keith@asus:~$ sudo apt-get install --reinstall network-manager network-manager-gnome
keith@asus:~$
Not having the icon is no real problem as I can always get to the network manager via the menus but it’s a nuisance if I am giving the machine to a friend and I would be grateful for advice.
Re: Network manager icon missing in Ubuntu 18.04
« Reply #1 on: July 11, 2019, 07:27:16 pm »
does running
nm-applet
make the panel applet appear (as long as the terminal stays open) ?
« Reply #2 on: July 11, 2019, 07:53:28 pm »
Perfect!  And it remains even when the terminal is closed.
You're a star!
