Author Topic: Ubuntu 18: Lost icons in top right of Classic View [SOLVED]  (Read 6229 times)
ASUSTeK P6-P5G41E running Ubuntu 18.04 in gnome-flashback
I thought I was removing just one icon from the top right panel but they all disappeared!
I've done this before (sorry!) but can't remember how to recover them, and my web search wasn't helpful.
I would be grateful for advice.
Thanks
[EDIT] Tried dconf reset -f /org/gnome/gnome-panel/ without success.
[EDIT 2] Tried:
killall gnome-panel
sudo apt-get install --reinstall gnome-panel gnome-applets
sudo apt-get -f install
...after this, ALL the top panels disappeared but a reboot restored them.  Success!
« Last Edit: July 23, 2019, 08:07:37 pm by Keith »
Re: Ubuntu 18: Lost icons in top right of Classic View [SOLVED]
« Reply #1 on: July 24, 2019, 01:35:14 pm »
Great stuff Keith :)
« Reply #2 on: July 24, 2019, 08:30:08 pm »
Thank you Mark.  That's good for my ego but I can't claim any skill here as I ought to have acknowledged the solution at https://ubuntuforums.org/showthread.php?t=2248429&p=13143988#post13143988.
Just shows that if one keeps searching for long enough the answers are usually out there somewhere.  Or more usually, here.
« Reply #3 on: July 25, 2019, 10:29:09 pm »
No matter where it comes from, understanding the problem and how to find a/the solution is a skill.
