Author Topic: [solved] Wi-Fi cameras  (Read 992 times)
Offline mikep
  • Sr. Member
  • Me again!
« on: July 26, 2019, 09:13:04 pm »
Evenin' All,
I'm thinking of getting a Kasa camera in order to monitor the house when I'm away.
Some reviews suggest that they're not appropriate for the UK as they require an input of 100-120v, rather than the UK's 240v.
The suggestion is that this involves risk of fire. However, as I understand it, electrical devices draw only as much power as they need, so there should be no problem if too much power is available.
Am I right? I want to monitor the house, not burn it down!
TiA,
Mike
« Last Edit: August 01, 2019, 11:35:07 pm by mikep »
Re: Wi-Fi cameras
« Reply #1 on: July 26, 2019, 09:25:59 pm »
From what I'm seeing the Kasa smart cameras all seem to be made by TP-Link and use 100-240 volt AC adapters.
So which particular model are you looking at ?
« Last Edit: July 26, 2019, 09:32:10 pm by Mark Greaves (PCNetSpec) »
Re: Wi-Fi cameras
Offline mikep
  • Sr. Member
  • Me again!
Re: Wi-Fi cameras
« Reply #2 on: July 30, 2019, 06:45:17 pm »
Hello Mark,
I'm looking at the KC120. I found various comments online stating that it doesn't work in the UK, and that the required voltage is 100-120v.
I've just looked at the TP-Link website which states 100-240V AC, 50/60Hz, 0.2A, so it seems you're quite right.
I'm wondering whether those people complaining bought from Amazon.com instead of Amazon.co.uk and paid extra shipping for the privilege of buying the wrong item..
Re: Wi-Fi cameras
« Reply #3 on: July 30, 2019, 10:15:09 pm »
I would have expected the adapter to be the same in both countries as it covers both 110 and 240v
I can only assume they didn't do their homework and simply took a guess ;)
Offline mikep
  • Sr. Member
  • Me again!
Re: Wi-Fi cameras
« Reply #4 on: August 01, 2019, 12:18:45 am »
Not quite with you Mark,
If the adapter were the same in both countries, how could anyone guess wrong?
Mind you, an American plug would be completely different from a UK one - unless it comes with one of those new 'kits' whereby you just slip on the 'front end' that suits your location...
« Last Edit: August 01, 2019, 12:22:51 am by mikep »
Re: Wi-Fi cameras
Re: Wi-Fi cameras
« Reply #5 on: August 01, 2019, 09:56:02 pm »
Exactly .. they couldn't.
Offline mikep
  • Sr. Member
  • Me again!
Re: Wi-Fi cameras
« Reply #6 on: August 01, 2019, 11:34:12 pm »
Thanks Mark,
I'm going to call this solved now.
M
