Author Topic: Transmission download  (Read 1773 times)
Offline Toplap
  • Freedom
« on: August 06, 2019, 10:51:09 am »
Hi, can anyone help me to download Transmission.  This is for my second laptop on which I use Zorin. I copied a video from youtube and got:
sudo add-apt-repository ppa:transmission/ppa
[sudo] password for joe:
Cannot add PPA: 'ppa:~transmission/ubuntu/ppa'.
The user named '~transmission' does not have any PPA
Please note I tried in the terminal because I cannot download it through my desktop because it insists I register an account with Ubuntu and every time I try to, it won't let me. Thanks.
Re: Transmission download
« Reply #1 on: August 06, 2019, 04:06:53 pm »
a) what's wrong with the version of transmission in the default repos (2.92) ?
and if you MUST have 2.94 for some reason...
b) shouldn't that be
sudo add-apt-repository ppa:transmissionbt/ppa
Offline Toplap
  • Freedom
« Reply #2 on: August 06, 2019, 10:30:44 pm »
Thanks, but I can't find transmission.  When I search for it...nothing.  When I attempt to download a movie for example I can't.  I used to do it in Mint and it would work automatically...in Zorin nothing happens.
Offline SeZo
« Reply #3 on: August 07, 2019, 09:58:30 am »
Never used Zorin, so cannot test this, but as I understand it is based on Ubuntu so it should work:
sudo apt install transmission-gtk transmission-common
Offline Toplap
  • Freedom
« Reply #4 on: August 07, 2019, 10:10:24 am »
Thanks for the replies.
