Author Topic: Spotify  (Read 1464 times)
Offline pauly66
Spotify
« on: August 10, 2019, 11:56:31 am »
Hi Guys
Having a few difficulties trying to install spotify on my linux 19.1 . I have followed all types of tutorials but it just wont install, even tried the spotify app that is in software package and that hung . installing manually I get to the end where I use the command of get upadates then I get the message :
 spotify-client : Depends: libcurl3 but it is not going to be installed
Not being too savvy I am at a loss at what this means can someone point me in the right direction please
cheers
Paul
Offline wishbone
Re: Spotify
« Reply #1 on: August 10, 2019, 07:30:14 pm »
Re: Spotify
« Reply #2 on: August 12, 2019, 11:58:00 am »
Try manually installing libcurl3
sudo apt-get install libcurl3
then try again installing spotify
Offline pauly66
Re: Spotify
« Reply #3 on: August 12, 2019, 08:39:44 pm »
Thank you Mark and wishbone installed libcurl and retried installing using the 2nd link in wishbones post and voila installed all ok so once again Thank you both for your help i didn't realise libcurl was needed or how to get it
