Author Topic: Help needed with FREE CAD programmes (Solved)  (Read 1075 times)
Offline donwatson
  • Getting older
« on: August 30, 2019, 04:29:37 pm »
When I recently went to run DraftSight it said my trial had expired and to log in and get an update. I tried this but have not been able to get it installed and running to date. I was then told that the FREE version would be unavailable from the end of December so I thought it a waste of time to install for a couple of months as I didn't intend purchasing it.
I also have bricscadV17 listed in the Graphics table and it doesn't work either, when I click on it nothing happens.
I have installed LibreCad and it works ok.
Can you help me get rid of DraftSight and bricscad ??
Thanks again
Don W
« Last Edit: September 15, 2019, 09:42:01 am by donwatson »
Novatech build
External 2TiB HD
Offline SeZo
Re: Help needed with FREE CAD programmes
« Reply #1 on: August 30, 2019, 07:58:37 pm »
You should be able to continue to run DraftSight 2019 for free on Linux:
Mac and Linux users may access DraftSight 2019 Beta below at no cost.
See here https://www.3ds.com/products-services/draftsight-cad-software/download-draftsight/
Otherwise you can follow the uninstall instructions from here:
https://www.3ds.com/products-services/draftsight-cad-software/uninstall/
Note, I am running 2019 version now and also BricsCAD 19.2 (trial) on Mint
Offline donwatson
  • Getting older
« Reply #2 on: September 01, 2019, 10:33:43 am »
Thanks for that Sezo. DraftSight is up and running again.
Do you think I will need BricsCad 19.2 (trial) after the free draftsight finishes ? maybe I should try it now just in case ??
thanks again
Don W
EDIT Thanks again SeZo, I have installed BricsCad 19.2 and it is working fine. I may send you a PM at a later date.
« Last Edit: September 02, 2019, 10:29:38 am by donwatson »
Novatech build
External 2TiB HD
