Author Topic: Very Slow Boot  (Read 3656 times)
Offline mkIV
Very Slow Boot
« on: September 08, 2019, 05:31:36 am »
Hello!! First post here. I have been playing around with linux for about 6 months now. Decided to play around with triple booting and I actually got it haha.
I am having a bit of a problem with my Mint not booting very fast. I have a HP Pavilion 15-t. Today I just upgraded from a mechanical HDD to a 1TB Samsung Evo 860 SSD. I have Windows 10, Mint, and Kali installed. Kali and Windows boot really fast now and I don't have any problems. Mint, on the other hand takes a few minutes and is actually slower than when I had my HDD installed. I ran
dmesg:     http://m.uploadedit.com/bbtc/1567916569189.txt
systemd-analyze critical-chain:  http://m.uploadedit.com/bbtc/1567916652578.txt
systemd-analyze blame:            http://m.uploadedit.com/bbtc/1567916676327.txt
My kernel is 4.5.0-60-generic
It probably has something to do with the swap or something. IDK
Oh, here't the blkid: http://m.uploadedit.com/bbtc/1567916962151.txt
Thank you guys so much in advance!!
« Last Edit: September 08, 2019, 05:34:54 am by mkIV »
Re: Very Slow Boot
« Reply #1 on: September 08, 2019, 03:43:11 pm »
In Mint, can you post the output from:
sudo fdisk -l
blkid
swapon -s
cat /etc/initramfs-tools/conf.d/resume
and the contents of
xed /etc/fstab
Re: Very Slow Boot
Offline mkIV
Re: Very Slow Boot
« Reply #2 on: September 08, 2019, 08:40:46 pm »
sudo fdisk -l
GPT PMBR size mismatch (976773167 != 1953525167) will be corrected by w(rite).
Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Disklabel type: gpt
Disk identifier: 426C6521-7809-47B0-BC98-3717EA47BDC7
Device          Start        End    Sectors  Size Type
/dev/sda1        2048    1050623    1048576  512M EFI System
/dev/sda2     1050624  615450623  614400000  293G Linux filesystem
/dev/sda3   615450624  615483391      32768   16M Microsoft reserved
/dev/sda4   615483392 1850572799 1235089408  589G Microsoft basic data
/dev/sda5  1850572800 1856552959    5980160  2.9G Windows recovery environment
/dev/sda6  1856552960 1928517631   71964672 34.3G Linux filesystem
/dev/sda7  1928517632 1953523711   25006080 11.9G Linux swap
blkid
/dev/sda1: UUID="77A3-530E" TYPE="vfat" PARTLABEL="EFI System Partition" PARTUUID="5716af3a-2476-4c22-a4c3-3d98cfeac3c0"
/dev/sda2: UUID="34e5f0cb-4239-472a-bec3-98646ca9e3ef" TYPE="ext4" PARTUUID="faf1b266-4d10-4d5e-8605-1504c4d080c1"
/dev/sda4: UUID="6A54E11954E0E931" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="3efab44e-5011-439e-853f-33c2cb140b8f"
/dev/sda5: UUID="30E201CCE20196EE" TYPE="ntfs" PARTUUID="e466a0d3-98c7-49e3-b327-bc6113903fce"
/dev/sda6: UUID="414df159-427e-426b-ade4-400090d1dbc2" TYPE="ext4" PARTUUID="fa05aefb-3c10-47a2-a520-8d38dd10418c"
/dev/sda7: UUID="66ed2cb6-18e8-411b-8186-e9d28fe8a377" TYPE="swap" PARTUUID="23a551b3-3657-4bc8-8125-2c8ac144bade"
swapon -s
swapon -s didn't output anything.
RESUME=UUID=65ad16d9-0930-431b-86d9-bf7d123e7082
xed /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=34e5f0cb-4239-472a-bec3-98646ca9e3ef / ext4 errors=remount-ro 0 1
#UUID=77A3-530E /boot/efi vfat umask=0077 0 1
UUID=65ad16d9-0930-431b-86d9-bf7d123e7082 none swap sw 0 0
UUID=77A3-530E /boot/efi vfat defaults 0 1
Hope this helps.
Again, thanks in advance!
Re: Very Slow Boot
« Reply #3 on: September 09, 2019, 02:04:04 am »
Okay looks like your /etc/fstab entry for the swap partition's UUID is wrong .. the UUID probably changed during the drive exchange.
We'll then also need to fix the entry in your /etc/initramfs-tools/conf.d/resume file to match.
Run:
sudo xed /etc/fstab
and make it read
# UUID=77A3-530E /boot/efi vfat umask=0077 0 1
# UUID=65ad16d9-0930-431b-86d9-bf7d123e7082 none swap sw 0 0
UUID=66ed2cb6-18e8-411b-8186-e9d28fe8a377 none swap sw 0 0
SAVE the file, and exit the text editor.
Back in the terminal run:
sudo xed /etc/initramfs-tools/conf.d/resume
and make it read
RESUME=UUID=66ed2cb6-18e8-411b-8186-e9d28fe8a377
Now REBOOT to test.
Now post the output from:
swapon -s
free -m
so we can see if swap got mounted properly.
« Last Edit: September 09, 2019, 02:12:58 am by Mark Greaves (PCNetSpec) »
Offline mkIV
Re: Very Slow Boot
« Reply #4 on: September 09, 2019, 02:56:24 am »
It is a little faster but Windows is still booting faster than Mint
Filename				Type		Size	Used	Priority
/dev/sda7                              partition 12503036 0 -2
              total        used        free      shared  buff/cache   available
Mem:          11931        1105        9875         180         950       10388
Swap:         12209           0       12209
Startup finished in 4.341s (firmware) + 2.684s (loader) + 35.436s (kernel) + 11.152s (userspace) = 53.614s
graphical.target reached after 11.009s in userspace
Re: Very Slow Boot
Offline mkIV
Re: Very Slow Boot
« Reply #5 on: September 09, 2019, 03:15:54 am »
Systemd-analyze for my Kali distribution shows:
Startup finished in 4.382s (firmware) + 2.384s (loader) + 4.001s (kernel) + 5.429s (userspace) = 16.197s
graphical.target reached after 5.417s in userspace
So I know Mint can be a bit faster than it is haha
Offline mkIV
Re: Very Slow Boot
« Reply #6 on: September 09, 2019, 03:44:27 am »
sda1: Bootloader
sda2: Linux Mint
sda3: Dumb extra partition for Windows 10 (bootloader files??)
sda4: Windows 10
sda5: I don't know why this is there (Windows related)
sda6: Kali Linux
sda7: swap
You guys know more than me, but I just wanted to try to give as much info as I could.
Not to get sidetracked, but:
1) Why is there only one linux-swap when I have 2 Linux operating systems? Does Kali use it, or just Mint?
2) What happens if I want to add to my ext4 partition for Mint? I don't see how I will be able to resize it since it's locked in between Bootloader and Windows.
« Last Edit: September 09, 2019, 03:46:22 am by mkIV »
Re: Very Slow Boot
« Reply #7 on: September 09, 2019, 03:41:56 pm »
As you don't seem to be using BTRFS, and there's a 31 second delay in dmesg between the btrfs driver being loaded and sda2 being mounted (probably where the drive is being scanned for non-existent btrfs file systems):-
[    4.187586] Btrfs loaded, crc32c=crc32c-intel
[   35.357394] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
try uninstalling the unnecessary btrfs support:
sudo apt-get remove --purge btrfs-tools btrfs-progs
then rebuild the initramfs:
sudo update-initramfs -uk all
Then REBOOT to test.
If that still doesn't help. please post your dmesg output again.
They'll be happy sharing a swap partition, but there's nothing stopping you having separate swap partitions (or indeed a swap FILE for Mint) if you'd like.
Certainly it will be more difficult than if you'd manually positioned it at the end of the drive .. though not impossible, it'll just mean juggling/moving/resizing partitions around on the drive.
I do have to wonder though, what do you plan on doing where 240GB is not going to be enough for Mint ?
« Last Edit: September 09, 2019, 03:57:09 pm by Mark Greaves (PCNetSpec) »
Offline mkIV
Re: Very Slow Boot
« Reply #8 on: September 09, 2019, 06:17:10 pm »
Startup finished in 4.394s (firmware) + 2.454s (loader) + 34.725s (kernel) + 17.696s (userspace) = 59.271s
graphical.target reached after 17.537s in userspace
59 seconds is still a little slow, no?
Here is my dmesg output. I deleted a bunch of stuff at 0.00 because there was too much text.
[    3.228267] clocksource: Switched to clocksource tsc
[   34.605947] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[    0.000000] microcode: microcode updated early to revision 0x2d, date = 2019-03-07
[    0.000000] Linux version 4.15.0-60-generic ([email protected]) (gcc version 7.4.0 (Ubuntu 7.4.0-1ubuntu1~18.04.1)) #67-Ubuntu SMP Thu Aug 22 16:55:30 UTC 2019 (Ubuntu 4.15.0-60.67-generic 4.15.18)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-60-generic root=UUID=34e5f0cb-4239-472a-bec3-98646ca9e3ef ro text pci=nomsi quiet splash resume=UUID=65ad16d9-0930-431b-86d9-bf7d123e7082 vt.handoff=1
[    0.000000] DMAR: RMRR base: 0x0000009d800000 end: 0x0000009fffffff
[    0.000000] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.000000] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.000000] DMAR-IR: x2apic is disabled because BIOS sets x2apic opt out bit.
[    0.000000] DMAR-IR: Use 'intremap=no_x2apic_optout' to override the BIOS setting.
[    0.000000] DMAR-IR: Enabled IRQ remapping in xapic mode
[    0.000000] x2apic: IRQ remapping doesn't support X2APIC mode
[    0.000000] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.020000] tsc: Fast TSC calibration using PIT
[    0.024000] tsc: Detected 2394.285 MHz processor
[    0.024000] Calibrating delay loop (skipped), value calculated using timer frequency.. 4788.57 BogoMIPS (lpj=9577140)
[    0.024000] pid_max: default: 32768 minimum: 301
[    0.024000] Security Framework initialized
[    0.024000] Yama: becoming mindful.
[    0.024000] AppArmor: AppArmor initialized
[    0.028531] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[    0.029703] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.029752] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.029790] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.029988] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.029988] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.030001] CPU0: Thermal monitoring enabled (TM1)
[    0.030012] process: using mwait in idle threads
[    0.030015] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.030016] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.030017] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.030018] Spectre V2 : Mitigation: Full generic retpoline
[    0.030019] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.030019] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.030027] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.030027] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.030029] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.030054] MDS: Mitigation: Clear CPU buffers
[    0.036516] Freeing SMP alternatives memory: 36K
[    0.041198] TSC deadline timer enabled
[    0.041200] smpboot: CPU0: Intel(R) Core(TM) i7-5500U CPU @ 2.40GHz (family: 0x6, model: 0x3d, stepping: 0x4)
[    0.041268] Performance Events: PEBS fmt2+, Broadwell events, 16-deep LBR, full-width counters, Intel PMU driver.
[    0.041312] ... version:                3
[    0.041313] ... bit width:              48
[    0.041313] ... generic registers:      4
[    0.041314] ... value mask:             0000ffffffffffff
[    0.041314] ... max period:             00007fffffffffff
[    0.041315] ... fixed-purpose events:   3
[    0.041315] ... event mask:             000000070000000f
[    0.041348] Hierarchical SRCU implementation.
[    0.042347] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.042360] smp: Bringing up secondary CPUs ...
[    0.042435] x86: Booting SMP configuration:
[    0.042436] .... node  #0, CPUs:      #1 #2
[    0.044143] MDS CPU bug present and SMT on, data leak possible. See [url]https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html[/url] for more details.
[    0.044231]  #3
[    0.044648] smp: Brought up 1 node, 4 CPUs
[    0.044648] smpboot: Max logical packages: 1
[    0.044648] smpboot: Total of 4 processors activated (19154.28 BogoMIPS)
[    0.048312] devtmpfs: initialized
[    0.048312] x86/mm: Memory block size: 128MB
[    0.048963] evm: security.selinux
[    0.048964] evm: security.SMACK64
[    0.048964] evm: security.SMACK64EXEC
[    0.048965] evm: security.SMACK64TRANSMUTE
[    0.048965] evm: security.SMACK64MMAP
[    0.048966] evm: security.apparmor
[    0.048966] evm: security.ima
[    0.048967] evm: security.capability
[    0.048979] PM: Registering ACPI NVS region [mem 0x9cdbe000-0x9cfbdfff] (2097152 bytes)
[    0.048979] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.048979] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.048979] pinctrl core: initialized pinctrl subsystem
[    0.048979] RTC time: 17:04:28, date: 09/09/19
[    0.048979] NET: Registered protocol family 16
[    0.048979] audit: initializing netlink subsys (disabled)
[    0.048979] audit: type=2000 audit(1568048668.048:1): state=initialized audit_enabled=0 res=1
[    0.048979] cpuidle: using governor ladder
[    0.048979] cpuidle: using governor menu
[    0.048979] Detected 1 PCC Subspaces
[    0.048979] Registering PCC driver as Mailbox controller
[    0.048979] Simple Boot Flag at 0x44 set to 0x1
[    0.048979] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.048979] ACPI: bus type PCI registered
[    0.048979] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.048979] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.048979] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.048979] pmd_set_huge: Cannot satisfy [mem 0xe0000000-0xe0200000] with a huge-page mapping due to MTRR override.
[    0.048979] PCI: Using configuration type 1 for base access
[    0.049183] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.049183] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.052068] ACPI: Added _OSI(Module Device)
[    0.052069] ACPI: Added _OSI(Processor Device)
[    0.052069] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.052070] ACPI: Added _OSI(Processor Aggregator Device)
[    0.052071] ACPI: Added _OSI(Linux-Dell-Video)
[    0.052072] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.052073] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.052572] ACPI: Executed 6 blocks of module-level executable AML code
[    0.065455] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.065498] ACPI: Dynamic OEM Table Load:
[    0.065507] ACPI: SSDT 0xFFFF8F1B8FD90400 0003D3 (v02 PmRef  Cpu0Cst  00003001 INTL 20130117)
[    0.065722] ACPI: Dynamic OEM Table Load:
[    0.065722] ACPI: SSDT 0xFFFF8F1B902D9800 0005AA (v02 PmRef  ApIst    00003000 INTL 20130117)
[    0.068240] ACPI: Dynamic OEM Table Load:
[    0.068240] ACPI: SSDT 0xFFFF8F1B8FCCE200 000119 (v02 PmRef  ApCst    00003000 INTL 20130117)
[    0.069232] ACPI: EC: EC started
[    0.069232] ACPI: EC: interrupt blocked
[    0.213096] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
[    0.213098] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x8, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.213099] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions
[    0.213100] ACPI: Interpreter enabled
[    0.213142] ACPI: (supports S0 S3 S4 S5)
[    0.213143] ACPI: Using IOAPIC for interrupt routing
[    0.213184] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.213667] ACPI: GPE 0x61 active on init
[    0.213690] ACPI: Enabled 7 GPEs in block 00 to 7F
[    0.230627] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.230632] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments]
[    0.230796] acpi PNP0A08:00: _OSC: not requesting OS control; OS requires [ExtendedConfig ASPM ClockPM MSI]
[    0.231720] PCI host bridge to bus 0000:00
[    0.231722] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.231724] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.231725] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.231726] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[    0.231727] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[    0.231727] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[    0.231728] pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
[    0.231729] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.231730] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.231731] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.231732] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.231733] pci_bus 0000:00: root bus resource [mem 0xa0000000-0xfeafffff window]
[    0.231735] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.231742] pci 0000:00:00.0: [8086:1604] type 00 class 0x060000
[    0.232054] pci 0000:00:02.0: [8086:1616] type 00 class 0x030000
[    0.232065] pci 0000:00:02.0: reg 0x10: [mem 0xc1000000-0xc1ffffff 64bit]
[    0.232071] pci 0000:00:02.0: reg 0x18: [mem 0xb0000000-0xbfffffff 64bit pref]
[    0.232075] pci 0000:00:02.0: reg 0x20: [io  0x5000-0x503f]
[    0.232089] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.232407] pci 0000:00:03.0: [8086:160c] type 00 class 0x040300
[    0.232417] pci 0000:00:03.0: reg 0x10: [mem 0xc3218000-0xc321bfff 64bit]
[    0.232727] pci 0000:00:04.0: [8086:1603] type 00 class 0x118000
[    0.232739] pci 0000:00:04.0: reg 0x10: [mem 0xc3210000-0xc3217fff 64bit]
[    0.233061] pci 0000:00:14.0: [8086:9cb1] type 00 class 0x0c0330
[    0.233079] pci 0000:00:14.0: reg 0x10: [mem 0xc3200000-0xc320ffff 64bit]
[    0.233134] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.233418] pci 0000:00:16.0: [8086:9cba] type 00 class 0x078000
[    0.233437] pci 0000:00:16.0: reg 0x10: [mem 0xc3222000-0xc322201f 64bit]
[    0.233493] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.233780] pci 0000:00:1b.0: [8086:9ca0] type 00 class 0x040300
[    0.233798] pci 0000:00:1b.0: reg 0x10: [mem 0xc321c000-0xc321ffff 64bit]
[    0.233852] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.234133] pci 0000:00:1c.0: [8086:9c90] type 01 class 0x060400
[    0.234199] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.234558] pci 0000:00:1c.1: [8086:9c92] type 01 class 0x060400
[    0.234626] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[    0.234986] pci 0000:00:1c.2: [8086:9c94] type 01 class 0x060400
[    0.235054] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[    0.235410] pci 0000:00:1c.3: [8086:9c96] type 01 class 0x060400
[    0.235478] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    0.235825] pci 0000:00:1f.0: [8086:9cc3] type 00 class 0x060100
[    0.236219] pci 0000:00:1f.2: [8086:9c83] type 00 class 0x010601
[    0.236233] pci 0000:00:1f.2: reg 0x10: [io  0x5088-0x508f]
[    0.236239] pci 0000:00:1f.2: reg 0x14: [io  0x5094-0x5097]
[    0.236245] pci 0000:00:1f.2: reg 0x18: [io  0x5080-0x5087]
[    0.236251] pci 0000:00:1f.2: reg 0x1c: [io  0x5090-0x5093]
[    0.236256] pci 0000:00:1f.2: reg 0x20: [io  0x5060-0x507f]
[    0.236263] pci 0000:00:1f.2: reg 0x24: [mem 0xc3220000-0xc32207ff]
[    0.236295] pci 0000:00:1f.2: PME# supported from D3hot
[    0.236574] pci 0000:00:1f.3: [8086:9ca2] type 00 class 0x0c0500
[    0.236590] pci 0000:00:1f.3: reg 0x10: [mem 0xc3221000-0xc32210ff 64bit]
[    0.236607] pci 0000:00:1f.3: reg 0x20: [io  0x5040-0x505f]
[    0.236942] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.236987] pci 0000:00:1c.1: PCI bridge to [bus 02-07]
[    0.236990] pci 0000:00:1c.1:   bridge window [io  0x4000-0x4fff]
[    0.236992] pci 0000:00:1c.1:   bridge window [mem 0xc2000000-0xc2ffffff]
[    0.236996] pci 0000:00:1c.1:   bridge window [mem 0xc0000000-0xc0ffffff 64bit pref]
[    0.237253] pci 0000:08:00.0: [8086:3165] type 00 class 0x028000
[    0.237354] pci 0000:08:00.0: reg 0x10: [mem 0xc3100000-0xc3101fff 64bit]
[    0.237746] pci 0000:08:00.0: PME# supported from D0 D3hot D3cold
[    0.248178] pci 0000:00:1c.2: PCI bridge to [bus 08]
[    0.248182] pci 0000:00:1c.2:   bridge window [mem 0xc3100000-0xc31fffff]
[    0.248242] pci 0000:09:00.0: [10ec:8136] type 00 class 0x020000
[    0.248272] pci 0000:09:00.0: reg 0x10: [io  0x3000-0x30ff]
[    0.248298] pci 0000:09:00.0: reg 0x18: [mem 0xc3004000-0xc3004fff 64bit]
[    0.248315] pci 0000:09:00.0: reg 0x20: [mem 0xc3000000-0xc3003fff 64bit]
[    0.248411] pci 0000:09:00.0: supports D1 D2
[    0.248412] pci 0000:09:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.260024] pci 0000:00:1c.3: PCI bridge to [bus 09]
[    0.260027] pci 0000:00:1c.3:   bridge window [io  0x3000-0x3fff]
[    0.260029] pci 0000:00:1c.3:   bridge window [mem 0xc3000000-0xc30fffff]
[    0.261515] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.261586] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.261655] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.261723] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.261794] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.261863] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.261930] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.261998] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.262552] ACPI: EC: interrupt unblocked
[    0.262559] ACPI: EC: event unblocked
[    0.262565] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x8, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.262567] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions and events
[    0.262781] SCSI subsystem initialized
[    0.262792] libata version 3.00 loaded.
[    0.262792] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.262792] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.262792] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.262792] vgaarb: loaded
[    0.262792] ACPI: bus type USB registered
[    0.262792] usbcore: registered new interface driver usbfs
[    0.262792] usbcore: registered new interface driver hub
[    0.262792] usbcore: registered new device driver usb
[    0.262792] EDAC MC: Ver: 3.0.0
[    0.262792] Registered efivars operations
[    0.302400] PCI: Using ACPI for IRQ routing
[    0.307672] PCI: pci_cache_line_size set to 64 bytes
[    0.308000] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    0.308001] e820: reserve RAM buffer [mem 0x00086000-0x0008ffff]
[    0.308002] e820: reserve RAM buffer [mem 0x9c2be000-0x9fffffff]
[    0.308004] e820: reserve RAM buffer [mem 0x9cfff000-0x9fffffff]
[    0.308005] e820: reserve RAM buffer [mem 0x35f000000-0x35fffffff]
[    0.308098] NetLabel: Initializing
[    0.308098] NetLabel:  domain hash size = 128
[    0.308099] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.308112] NetLabel:  unlabeled traffic allowed by default
[    0.308464] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.308469] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.310490] clocksource: Switched to clocksource hpet
[    0.318665] VFS: Disk quotas dquot_6.6.0
[    0.318681] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.318779] AppArmor: AppArmor Filesystem Enabled
[    0.318807] pnp: PnP ACPI init
[    0.319361] system 00:00: [io  0x0680-0x069f] has been reserved
[    0.319363] system 00:00: [io  0xffff] has been reserved
[    0.319364] system 00:00: [io  0xffff] has been reserved
[    0.319365] system 00:00: [io  0xffff] has been reserved
[    0.319366] system 00:00: [io  0x1800-0x18fe] has been reserved
[    0.319367] system 00:00: [io  0x164e-0x164f] has been reserved
[    0.319369] system 00:00: [io  0x0454-0x0457] has been reserved
[    0.319372] system 00:00: [io  0x0380-0x0387] has been reserved
[    0.319377] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.319432] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.319485] pnp 00:02: Plug and Play ACPI device, IDs HPQ8001 PNP0303 (active)
[    0.319515] pnp 00:03: Plug and Play ACPI device, IDs SYN1ef2 SYN1e00 SYN0002 PNP0f13 (active)
[    0.319836] system 00:04: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.319837] system 00:04: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.319838] system 00:04: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.319839] system 00:04: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.319841] system 00:04: [mem 0xe0000000-0xefffffff] has been reserved
[    0.319842] system 00:04: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.319843] system 00:04: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.319845] system 00:04: [mem 0xfed45000-0xfed8ffff] could not be reserved
[    0.319846] system 00:04: [mem 0xff000000-0xffffffff] could not be reserved
[    0.319847] system 00:04: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.319849] system 00:04: [mem 0xa0010000-0xa001ffff] has been reserved
[    0.319850] system 00:04: [mem 0xa0000000-0xa000ffff] has been reserved
[    0.319853] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.320489] pnp: PnP ACPI: found 5 devices
[    0.326417] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.326444] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.326454] pci 0000:00:1c.1: PCI bridge to [bus 02-07]
[    0.326456] pci 0000:00:1c.1:   bridge window [io  0x4000-0x4fff]
[    0.326459] pci 0000:00:1c.1:   bridge window [mem 0xc2000000-0xc2ffffff]
[    0.326462] pci 0000:00:1c.1:   bridge window [mem 0xc0000000-0xc0ffffff 64bit pref]
[    0.326467] pci 0000:00:1c.2: PCI bridge to [bus 08]
[    0.326470] pci 0000:00:1c.2:   bridge window [mem 0xc3100000-0xc31fffff]
[    0.326476] pci 0000:00:1c.3: PCI bridge to [bus 09]
[    0.326478] pci 0000:00:1c.3:   bridge window [io  0x3000-0x3fff]
[    0.326481] pci 0000:00:1c.3:   bridge window [mem 0xc3000000-0xc30fffff]
[    0.326488] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.326489] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.326490] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.326491] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[    0.326492] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[    0.326493] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[    0.326495] pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
[    0.326496] pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
[    0.326497] pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
[    0.326498] pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
[    0.326499] pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
[    0.326500] pci_bus 0000:00: resource 15 [mem 0xa0000000-0xfeafffff window]
[    0.326501] pci_bus 0000:02: resource 0 [io  0x4000-0x4fff]
[    0.326502] pci_bus 0000:02: resource 1 [mem 0xc2000000-0xc2ffffff]
[    0.326503] pci_bus 0000:02: resource 2 [mem 0xc0000000-0xc0ffffff 64bit pref]
[    0.326504] pci_bus 0000:08: resource 1 [mem 0xc3100000-0xc31fffff]
[    0.326505] pci_bus 0000:09: resource 0 [io  0x3000-0x3fff]
[    0.326506] pci_bus 0000:09: resource 1 [mem 0xc3000000-0xc30fffff]
[    0.326634] NET: Registered protocol family 2
[    0.326812] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.326989] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.327104] TCP: Hash tables configured (established 131072 bind 65536)
[    0.327141] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[    0.327180] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[    0.327246] NET: Registered protocol family 1
[    0.327258] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.329021] PCI: CLS 64 bytes, default 64
[    0.329053] Unpacking initramfs...
[    1.176559] Freeing initrd memory: 58336K
[    1.176668] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.176669] software IO TLB: mapped [mem 0x97e0c000-0x9be0c000] (64MB)
[    1.176891] Scanning for low memory corruption every 60 seconds
[    1.177482] Initialise system trusted keyrings
[    1.177491] Key type blacklist registered
[    1.177517] workingset: timestamp_bits=36 max_order=22 bucket_order=0
[    1.178563] zbud: loaded
[    1.179043] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.179158] fuse init (API version 7.26)
[    1.180480] Key type asymmetric registered
[    1.180480] Asymmetric key parser 'x509' registered
[    1.180506] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.180539] io scheduler noop registered
[    1.180540] io scheduler deadline registered
[    1.180562] io scheduler cfq registered (default)
[    1.181267] efifb: probing for efifb
[    1.181281] efifb: framebuffer at 0xb0000000, using 4160k, total 4160k
[    1.181282] efifb: mode is 1366x768x32, linelength=5504, pages=1
[    1.181282] efifb: scrolling: redraw
[    1.181283] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    1.181365] Console: switching to colour frame buffer device 170x48
[    1.181381] fb0: EFI VGA frame buffer device
[    1.181388] intel_idle: MWAIT substates: 0x11142120
[    1.181388] intel_idle: v0.4.1 model 0x3D
[    1.181560] intel_idle: lapic_timer_reliable_states 0xffffffff
[    1.181846] ACPI: AC Adapter [ADP1] (on-line)
[    1.181905] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[    1.181912] ACPI: Lid Switch [LID0]
[    1.181938] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    1.181944] ACPI: Power Button [PWRB]
[    1.181971] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    1.181989] ACPI: Power Button [PWRF]
[    1.183181] [Firmware Bug]: Invalid critical threshold (0)
[    1.184672] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[    1.185232] thermal LNXTHERM:00: registered as thermal_zone0
[    1.185232] ACPI: Thermal Zone [TZ01] (58 C)
[    1.185412] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    1.188422] Linux agpgart interface v0.103
[    1.252222] ACPI: Battery Slot [BAT0] (battery present)
[    1.276403] loop: module loaded
[    1.276567] libphy: Fixed MDIO Bus: probed
[    1.276568] tun: Universal TUN/TAP device driver, 1.6
[    1.276618] PPP generic driver version 2.4.2
[    1.276678] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.276679] ehci-pci: EHCI PCI platform driver
[    1.276689] ehci-platform: EHCI generic platform driver
[    1.276699] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.276701] ohci-pci: OHCI PCI platform driver
[    1.276707] ohci-platform: OHCI generic platform driver
[    1.276713] uhci_hcd: USB Universal Host Controller Interface driver
[    1.276886] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.276891] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    1.277952] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x000000000004b810
[    1.277956] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    1.278048] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.278049] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.278050] usb usb1: Product: xHCI Host Controller
[    1.278051] usb usb1: Manufacturer: Linux 4.15.0-60-generic xhci-hcd
[    1.278052] usb usb1: SerialNumber: 0000:00:14.0
[    1.278156] hub 1-0:1.0: USB hub found
[    1.278167] hub 1-0:1.0: 11 ports detected
[    1.280959] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.280961] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.280964] xhci_hcd 0000:00:14.0: Host supports USB 3.0  SuperSpeed
[    1.280991] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.280992] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.280993] usb usb2: Product: xHCI Host Controller
[    1.280994] usb usb2: Manufacturer: Linux 4.15.0-60-generic xhci-hcd
[    1.280995] usb usb2: SerialNumber: 0000:00:14.0
[    1.281099] hub 2-0:1.0: USB hub found
[    1.281105] hub 2-0:1.0: 4 ports detected
[    1.282641] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    1.289934] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.289938] serio: i8042 AUX port at 0x60,0x64 irq 12
[    1.290080] mousedev: PS/2 mouse device common for all mice
[    1.290307] rtc_cmos 00:01: RTC can wake from S4
[    1.290430] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[    1.290456] rtc_cmos 00:01: alarms up to one month, 242 bytes nvram, hpet irqs
[    1.290461] i2c /dev entries driver
[    1.290503] device-mapper: uevent: version 1.0.3
[    1.290570] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: [email protected]
[    1.290577] intel_pstate: Intel P-state driver initializing
[    1.290787] ledtrig-cpu: registered to indicate activity on CPUs
[    1.290790] EFI Variables Facility v0.08 2004-May-17
[    1.325212] NET: Registered protocol family 10
[    1.328940] Segment Routing with IPv6
[    1.328954] NET: Registered protocol family 17
[    1.328988] Key type dns_resolver registered
[    1.329173] mce: Using 7 MCE banks
[    1.329182] RAS: Correctable Errors collector initialized.
[    1.329211] microcode: sig=0x306d4, pf=0x40, revision=0x2d
[    1.329250] microcode: Microcode Update Driver: v2.2.
[    1.329257] sched_clock: Marking stable (1329246137, 0)->(1659269870, -330023733)
[    1.329403] registered taskstats version 1
[    1.329412] Loading compiled-in X.509 certificates
[    1.331793] Loaded X.509 cert 'Build time autogenerated kernel key: 9d88e3c0462fa0d2df2917e8bbfdfdd1c55d8ddc'
[    1.333766] Loaded UEFI:db cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53' linked to secondary sys keyring
[    1.333781] Loaded UEFI:db cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4' linked to secondary sys keyring
[    1.333795] Loaded UEFI:db cert 'Hewlett-Packard Company: HP UEFI Secure Boot 2013 DB key: 1d7cf2c2b92673f69c8ee1ec7063967ab9b62bec' linked to secondary sys keyring
[    1.336838] Loaded UEFI:MokListRT cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63' linked to secondary sys keyring
[    1.338479] zswap: loaded using pool lzo/zbud
[    1.341984] Key type big_key registered
[    1.341988] Key type trusted registered
[    1.343613] Key type encrypted registered
[    1.343616] AppArmor: AppArmor sha1 policy hashing enabled
[    1.349126] ima: Allocated hash algorithm: sha1
[    1.364043] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[    1.398919] evm: HMAC attrs: 0x1
[    1.399633]   Magic number: 3:12:87
[    1.399665] button LNXPWRBN:00: hash matches
[    1.399749] rtc_cmos 00:01: setting system clock to 2019-09-09 17:04:30 UTC (1568048670)
[    1.399871] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    1.399871] EDD information not available.
[    1.616029] usb 1-3: new high-speed USB device number 2 using xhci_hcd
[    1.722179] Freeing unused kernel image memory: 2436K
[    1.728093] Write protecting the kernel read-only data: 20480k
[    1.729281] Freeing unused kernel image memory: 2008K
[    1.729571] Freeing unused kernel image memory: 1972K
[    1.736134] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.736135] x86/mm: Checking user space page tables
[    1.742180] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.808783] usb 1-3: New USB device found, idVendor=04f2, idProduct=b50d
[    1.808786] usb 1-3: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    1.808787] usb 1-3: Product: HP Truevision HD
[    1.808789] usb 1-3: Manufacturer: Generic
[    1.808790] usb 1-3: SerialNumber: 200901010001
[    1.817399] wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
[    1.817422] wmi_bus wmi_bus-PNP0C14:00: WQBJ data block query control method not found
[    1.821919] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    1.821927] r8169 0000:09:00.0: can't disable ASPM; OS doesn't have ASPM control
[    1.825265] ahci 0000:00:1f.2: version 3.0
[    1.833764] r8169 0000:09:00.0 eth0: RTL8107e at 0x        (ptrval), 94:57:a5:db:1d:94, XID 14100800 IRQ 19
[    1.836009] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 6 Gbps 0x3 impl SATA mode
[    1.836012] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo only pio slum part deso sadm sds apst
[    1.839777] scsi host0: ahci
[    1.839888] scsi host1: ahci
[    1.840003] scsi host2: ahci
[    1.840180] scsi host3: ahci
[    1.840226] ata1: SATA max UDMA/133 abar [email protected] port 0xc3220100 irq 19
[    1.840228] ata2: SATA max UDMA/133 abar [email protected] port 0xc3220180 irq 19
[    1.840229] ata3: DUMMY
[    1.840230] ata4: DUMMY
[    1.844992] r8169 0000:09:00.0 eno1: renamed from eth0
[    1.886455] [drm] Memory usable by graphics device = 4096M
[    1.886457] checking generic (b0000000 410000) vs hw (b0000000 10000000)
[    1.886458] fb: switching to inteldrmfb from EFI VGA
[    1.886480] Console: switching to colour dummy device 80x25
[    1.886570] [drm] Replacing VGA console driver
[    1.892122] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.892123] [drm] Driver supports precise vblank timestamp query.
[    1.894275] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    1.901565] [drm] Initialized i915 1.6.0 20171023 for 0000:00:02.0 on minor 0
[    1.903170] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    1.903466] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6
[    1.920455] fbcon: inteldrmfb (fb0) is primary device
[    1.920517] Console: switching to colour frame buffer device 170x48
[    1.920544] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    1.944110] usb 1-7: new full-speed USB device number 3 using xhci_hcd
[    2.092996] usb 1-7: New USB device found, idVendor=8087, idProduct=0a2a
[    2.092998] usb 1-7: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.155169] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    2.155185] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    2.155670] ata1.00: supports DRM functions and may not be fully accessible
[    2.156840] ata1.00: ATA-11: Samsung SSD 860 EVO 1TB, RVT02B6Q, max UDMA/133
[    2.156842] ata1.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
[    2.157874] ata2.00: ATAPI: hp       DVDRW  GUB0N, UB00, max UDMA/133
[    2.159741] ata1.00: supports DRM functions and may not be fully accessible
[    2.161359] ata2.00: configured for UDMA/133
[    2.163061] random: fast init done
[    2.163073] ata1.00: configured for UDMA/133
[    2.163339] scsi 0:0:0:0: Direct-Access     ATA      Samsung SSD 860  2B6Q PQ: 0 ANSI: 5
[    2.163598] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    2.163623] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    2.163628] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    2.163675] ata1.00: Enabling discard_zeroes_data
[    2.163710] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    2.163793] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    2.163813] sd 0:0:0:0: [sda] Write Protect is off
[    2.163816] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.163847] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.163973] ata1.00: Enabling discard_zeroes_data
[    2.165084] scsi 1:0:0:0: CD-ROM            hp       DVDRW  GUB0N     UB00 PQ: 0 ANSI: 5
[    2.165762]  sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7
[    2.166021] ata1.00: Enabling discard_zeroes_data
[    2.167567] sd 0:0:0:0: [sda] supports TCG Opal
[    2.167568] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.204159] tsc: Refined TSC clocksource calibration: 2394.456 MHz
[    2.204167] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2283c236f90, max_idle_ns: 440795217409 ns
[    2.227790] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[    2.227792] cdrom: Uniform CD-ROM driver Revision: 3.20
[    2.227923] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    2.228005] sr 1:0:0:0: Attached scsi generic sg1 type 5
[    2.664171] psmouse serio1: synaptics: queried max coordinates: x [..5656], y [..4712]
[    2.702564] psmouse serio1: synaptics: queried min coordinates: x [1326..], y [1200..]
[    2.702570] psmouse serio1: synaptics: Your touchpad (PNP: SYN1ef2 SYN1e00 SYN0002 PNP0f13) says it can support a different bus. If i2c-hid and hid-rmi are not used, you might want to try setting psmouse.synaptics_intertouch to 1 and report this to [email protected]
[    2.778117] psmouse serio1: synaptics: Touchpad model: 1, fw: 8.1, id: 0x1e2b1, caps: 0xd00123/0x840300/0x12e800/0x0, board id: 2997, fw id: 1665536
[    2.826048] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input5
[   34.752885] ip_tables: (C) 2000-2006 Netfilter Core Team
[   34.821883] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[   34.840192] systemd[1]: Detected architecture x86-64.
[   34.842543] systemd[1]: Set hostname to <jed-megan-HP-Pavilion>.
[   34.949103] systemd[1]: Reached target User and Group Name Lookups.
[   34.949186] systemd[1]: Started ntp-systemd-netif.path.
[   34.949330] systemd[1]: Created slice User and Session Slice.
[   34.949346] systemd[1]: Reached target Remote File Systems.
[   34.949385] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   34.949492] systemd[1]: Created slice System Slice.
[   34.949583] systemd[1]: Listening on Journal Socket.
[   34.962694] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
[   34.987974] lp: driver loaded but no devices found
[   35.008318] ppdev: user-space parallel port driver
[   35.038147] systemd-journald[376]: Received request to flush runtime journal from PID 1
[   35.069831] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[   35.083139] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   35.095457] random: crng init done
[   35.095458] random: 7 urandom warning(s) missed due to ratelimiting
[   35.226171] input: HP Wireless hotkeys as /devices/virtual/input/input7
[   35.264930] hp_accel: laptop model unknown, using default axes configuration
[   35.276743] lis3lv02d: 8 bits 3DC sensor found
[   35.297126] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   35.304909] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[   35.309062] input: ST LIS3LV02DL Accelerometer as /devices/platform/lis3lv02d/input/input8
[   35.330212] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   35.330505] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   35.339547] Intel(R) Wireless WiFi driver for Linux
[   35.339548] Copyright(c) 2003- 2015 Intel Corporation
[   35.340570] iwlwifi 0000:08:00.0: pci_enable_msi failed - -22
[   35.356757] iwlwifi 0000:08:00.0: loaded firmware version 29.1044073957.0 op_mode iwlmvm
[   35.363893] hp_wmi: query 0xd returned error 0x5
[   35.363942] input: HP WMI hotkeys as /devices/virtual/input/input9
[   35.383082] iwlwifi 0000:08:00.0: Detected Intel(R) Dual Band Wireless AC 3165, REV=0x210
[   35.405022] iwlwifi 0000:08:00.0: base HW address: 94:65:9c:94:dc:11
[   35.434444] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[   35.434446] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   35.434446] RAPL PMU: hw unit of domain package 2^-14 Joules
[   35.434447] RAPL PMU: hw unit of domain dram 2^-14 Joules
[   35.434447] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[   35.438972] snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   35.456731] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input10
[   35.456793] input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card0/input11
[   35.456850] input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card0/input12
[   35.456899] input: HDA Intel HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.0/sound/card0/input13
[   35.456950] input: HDA Intel HDMI HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.0/sound/card0/input14
[   35.460133] Adding 12503036k swap on /dev/sda7.  Priority:-2 extents:1 across:12503036k SSFS
[   35.465375] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC3241: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[   35.465377] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   35.465379] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
[   35.465380] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[   35.465381] snd_hda_codec_realtek hdaudioC1D0:    inputs:
[   35.465383] snd_hda_codec_realtek hdaudioC1D0:      Mic=0x1a
[   35.465384] snd_hda_codec_realtek hdaudioC1D0:      Internal Mic=0x12
[   35.473107] AVX2 version of gcm_enc/dec engaged.
[   35.473108] AES CTR mode by8 optimization enabled
[   35.479835] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[   35.480799] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[   35.480817] thermal thermal_zone3: failed to read out thermal zone (-61)
[   35.513874] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input15
[   35.513940] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input16
[   35.531809] kvm: disabled by bios
[   35.595501] kvm: disabled by bios
[   35.622420] kvm: disabled by bios
[   35.633733] intel_rapl: Found RAPL domain package
[   35.633735] intel_rapl: Found RAPL domain core
[   35.633736] intel_rapl: Found RAPL domain uncore
[   35.633737] intel_rapl: Found RAPL domain dram
[   35.633739] intel_rapl: RAPL package 0 domain package locked by BIOS
[   35.633744] intel_rapl: RAPL package 0 domain dram locked by BIOS
[   35.652771] audit: type=1400 audit(1568048704.748:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=727 comm="apparmor_parser"
[   35.652775] audit: type=1400 audit(1568048704.748:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=727 comm="apparmor_parser"
[   35.652777] audit: type=1400 audit(1568048704.748:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=727 comm="apparmor_parser"
[   35.653975] audit: type=1400 audit(1568048704.748:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=725 comm="apparmor_parser"
[   35.653979] audit: type=1400 audit(1568048704.748:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=725 comm="apparmor_parser"
[   35.653981] audit: type=1400 audit(1568048704.748:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=725 comm="apparmor_parser"
[   35.653983] audit: type=1400 audit(1568048704.748:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=725 comm="apparmor_parser"
[   35.660854] audit: type=1400 audit(1568048704.756:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=724 comm="apparmor_parser"
[   35.660858] audit: type=1400 audit(1568048704.756:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=724 comm="apparmor_parser"
[   35.661584] audit: type=1400 audit(1568048704.756:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=728 comm="apparmor_parser"
[   35.663745] kvm: disabled by bios
[   35.761905] iwlwifi 0000:08:00.0 wlo1: renamed from wlan0
[   36.298138] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[   36.346673] r8169 0000:09:00.0 eno1: link down
[   36.346776] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[   36.349988] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[   36.457316] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[   36.543025] IPv6: ADDRCONF(NETDEV_UP): wlo1: link is not ready
[   36.547100] media: Linux media interface: v0.10
[   36.549778] Bluetooth: Core ver 2.22
[   36.549827] NET: Registered protocol family 31
[   36.549828] Bluetooth: HCI device and connection manager initialized
[   36.549831] Bluetooth: HCI socket layer initialized
[   36.549833] Bluetooth: L2CAP socket layer initialized
[   36.549839] Bluetooth: SCO socket layer initialized
[   36.553638] Linux video capture interface: v2.00
[   36.696629] usbcore: registered new interface driver btusb
[   36.704698] uvcvideo: Found UVC 1.00 device HP Truevision HD (04f2:b50d)
[   36.709981] uvcvideo 1-3:1.0: Entity type for entity Extension 4 was not initialized!
[   36.709984] uvcvideo 1-3:1.0: Entity type for entity Processing 2 was not initialized!
[   36.709985] uvcvideo 1-3:1.0: Entity type for entity Camera 1 was not initialized!
[   36.710228] input: HP Truevision HD: HP Truevision as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input17
[   36.710777] Bluetooth: hci0: read Intel version: 370810011003110e00
[   36.711310] usbcore: registered new interface driver uvcvideo
[   36.711311] USB Video Class driver (1.1.1)
[   36.711679] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-1.10.3.11.e.bseq
[   36.719178] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   36.719180] Bluetooth: BNEP filters: protocol multicast
[   36.719183] Bluetooth: BNEP socket layer initialized
[   36.962746] Bluetooth: hci0: unexpected event for opcode 0xfc2f
[   36.979773] Bluetooth: hci0: Intel firmware patch completed and activated
[   39.819306] wlo1: authenticate with 34:fc:b9:69:92:90
[   39.825116] wlo1: send auth to 34:fc:b9:69:92:90 (try 1/3)
[   39.827048] wlo1: authenticated
[   39.828121] wlo1: associate with 34:fc:b9:69:92:90 (try 1/3)
[   39.829214] wlo1: RX AssocResp from 34:fc:b9:69:92:90 (capab=0x401 status=0 aid=1)
[   39.830619] wlo1: associated
[   39.831315] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[   41.881911] Bluetooth: RFCOMM TTY layer initialized
[   41.881916] Bluetooth: RFCOMM socket layer initialized
[   41.881921] Bluetooth: RFCOMM ver 1.11
[   42.410234] vboxdrv: loading out-of-tree module taints kernel.
[   42.410456] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[   42.423920] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based  firewall rule not found. Use the iptables CT target to attach helpers instead.
[   42.428482] vboxdrv: Found 4 processor cores
[   42.429763] Guest personality initialized and is inactive
[   42.432776] VMCI host device registered (name=vmci, major=10, minor=51)
[   42.432778] Initialized host personality
[   42.455045] vboxdrv: TSC mode is Invariant, tentative frequency 2394455255 Hz
[   42.455046] vboxdrv: Successfully loaded version 5.2.32_Ubuntu (interface 0x00290001)
[   42.468267] VBoxNetFlt: Successfully started.
[   42.477787] VBoxNetAdp: Successfully started.
[   42.488942] VBoxPciLinuxInit
[   42.495814] NET: Registered protocol family 40
[   42.495978] vboxpci: IOMMU not found (not registered)
[   50.685284] atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
[   50.685286] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
[   50.743953] atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
[   50.743956] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
[   50.833128] atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
[   50.833131] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
[   50.902493] atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
[   50.902496] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
[   50.965957] atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
[   50.965960] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
[   51.048085] atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
[   51.048087] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
[   51.133356] atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
[   51.133358] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
[   51.200633] atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
[   51.200636] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
[   52.349555] ahci 0000:00:1f.2: port does not support device sleep
To answer your question about the space, I just wanted them to be a little bit more equal. But honestly I have more tools that I use for windows and now that it actually boots in a reasonable amount of time I'm not so worried about windows being my primary OS. But there's still (as y'all know) a LOT of cool stuff that Linux can do and I'd like to be able to get back and forth between them easily.
Re: Very Slow Boot
Re: Very Slow Boot
« Reply #9 on: September 09, 2019, 09:15:03 pm »
Do you know how to run a file system check on sda2 ?
Offline mkIV
Re: Very Slow Boot
« Reply #10 on: September 10, 2019, 02:54:49 am »
No, not really. But I have found a couple tutorials and I'll play around with it.
I do remember that there were a bunch of bad sectors in my HDD, so this transfer could have created some issues I guess
Re: Very Slow Boot
« Reply #11 on: September 10, 2019, 04:36:05 pm »
Basically you're going to need a LiveUSB to boot from .. have you got access to one ?
Preferably a Mint one ?
