Author Topic: Mount image file to partitions  (Read 1980 times)
Offline ABP
« on: September 28, 2019, 09:02:10 am »
Hi
I downloaded a device firmware.
Like this:
zetnu.xilinx-201907311618-autofreq-user-Update2UBI-NF-sig.tar.gz
I extract above file and file content is these files:
- BOOT.bin
- devicetree.dtb
- rootfs.jffs2
- uImage
Next to this files, was a file yo install.
This file:
runme.sh
This file content is this:
#!/bin/sh -e
path=$(pwd)
cp_config="all"
if [ ! -d /mnt/upgrade ];
    mkdir /mnt/upgrade
fi
if [ -e /usr/bin/ctrl_bd ]; then
ret=`cat /usr/bin/ctrl_bd | grep "XILINX" | wc -l`
else
ret=0
fi
if [ $ret -eq 1 ];then
    cd ./xilinx
    if [ -e /dev/ubi_ctrl ];then
        if [ ! -d /mnt/config ];then
            mkdir /mnt/config
        fi
        ubiattach /dev/ubi_ctrl -m 2
        mount -t ubifs ubi1:rootfs /mnt/config
        if [ ! -d /mnt/config/home/usr_config ];then
            mkdir /mnt/config/home/usr_config
        fi
        if [ `ls /mnt/config/home/usr_config | wc -l` -gt 1 ];then
            cp_config="all" #cp -r /config/* /mnt/config/home/usr_config/
        else
            cp_config="mac" #cp -r /config/mac /mnt/config/home/usr_config/
        fi
        umount /mnt/config
        ubidetach -d 1 /dev/ubi_ctrl
    fi
    if [ -e BOOT.bin ]; then
        flash_erase /dev/mtd0 0x0 0x80 >/dev/null 2>&1
        nandwrite -p -s 0x0 /dev/mtd0 ./BOOT.bin >/dev/null 2>&1
        rm -rf BOOT.bin
    fi
    if [ -e devicetree.dtb ]; then
        flash_erase /dev/mtd0 0x1020000 0x1 >/dev/null 2>&1
        nandwrite -p -s 0x1020000 /dev/mtd0 ./devicetree.dtb >/dev/null 2>&1
        rm devicetree.dtb
    fi
    if [ -e uImage ]; then
      flash_erase /dev/mtd0 0x1100000 0x40 >/dev/null 2>&1
      nandwrite -p -s 0x1100000 /dev/mtd0 ./uImage >/dev/null 2>&1
      rm uImage
    fi
    if [ -e rootfs.jffs2 ]; then
      if [ -f /dev/mtd3 ];then
          flash_erase /dev/mtd2 0x0 0x1E0 >/dev/null 2>&1
      else
          flash_erase /dev/mtd2 0x0 0x280 >/dev/null 2>&1
      fi
      nandwrite -p -s 0x0 /dev/mtd2 ./rootfs.jffs2 >/dev/null 2>&1
      rm rootfs.jffs2
    fi
            mkdir /mnt/config
        fi
        fi
        if [ $cp_config == "all" ];then
            if [ -e ../lighttpd-htdigest.user ]; then
               line1=`cat ../lighttpd-htdigest.user | wc -c`
               if [ $line1 != "0" ]; then
                   cp -r ../lighttpd-htdigest.user /mnt/config/home/usr_config/lighttpd-htdigest.user
                   if [ -e ../shadow ]; then
                       line2=`cat ../shadow | wc -c`
                       if [ $line2 != "0" ]; then
                           cp /etc/shadow /mnt/config/home/usr_config/shadow
                           old_shd=`sed -n '1p' /mnt/config/home/usr_config/shadow`
                           o1=`echo ${old_shd:5}`
                           o2=${o1#*:}
                           new_shd=`cat ../shadow`
                           n1=$new_shd":"$o2
                           sed -i '1d' /mnt/config/home/usr_config/shadow
                           sed -i "1i $(echo $n1)" /mnt/config/home/usr_config/shadow
                       fi
                   fi
               fi
            fi
        else
        fi
        sync
        umount /mnt/config
    fi
        mount -t ubifs ubi1:rootfs /mnt/upgrade
        cd /mnt/upgrade/upgrade
        rm -rf /mnt/upgrade/upgrade/*
        cd $path
        if [ -e ./xilinx/angstrom_rootfs.jffs2 ];then
            cp -rf ./xilinx/angstrom_rootfs.jffs2 /mnt/upgrade/upgrade
                flash_erase /dev/mtd3 0 0xa0 >/dev/null 2>&1
            fi
        fi
        flash_erase /dev/mtd0 0x1040000 0x1 >/dev/null 2>&1
        nandwrite -p -s 0x1040000 /dev/mtd0 ./xilinx/upgrade-marker.bin >/dev/null 2>&1
        sync
        umount /mnt/upgrade
    fi
else
    echo "this is not for c5"
fi
rm -rf *.tar.gz
#/sbin/reboot -f &
Above code used nandwrite to write in a device.
Now, I want to mount these images to a directory or partitions. and add or change somethings to these images. next write again to images.
How can I do it?
Step 1, I just want to mount and read file and directories.
Please help me.
Thanks
