Author Topic: Scanner not working- SOLVED!  (Read 4429 times)
Offline Melissa
  • Vintage nerd
  • Gender: Female
« on: October 08, 2019, 09:16:16 pm »
Hey guys can't get my scanner to work on my netbook, Asus Peppermint latest version. It says unable to connect.
« Last Edit: March 15, 2020, 10:44:57 pm by Melissa »
My computers:
Asus Chromebook
Asus notebook x102B, running on Peppermint 9.
Re: Scanner not working
« Reply #1 on: October 09, 2019, 06:36:03 pm »
What says "unable to connect" ?
What's the make/model of scanner ?
How is the scanner connected ?
Offline Melissa
  • Vintage nerd
  • Gender: Female
« Reply #2 on: October 10, 2019, 10:53:51 am »
Simple Scan on the Asus notebook/netbook says it can't connect. The scanner is the same one I had been using on the old Mint Dell netbook ( which I have now given to my mate Dave as he needed a small laptop to type up documents on). It's an old one but still in good nick and was working great on the Mint netbook. It's a Packard Bell Diamond 1200. Just plugged into the netbook via a USB cable.
My computers:
Asus Chromebook
« Reply #3 on: October 10, 2019, 05:54:44 pm »
Install sane-utils
sudo apt-get install sane-utils
then post the output from
scanimage
scanimage -L
sudo scanimage -L
sane-find-scanner
sudo sane-find-scanner
These links are only here for my future reference
https://forums.linuxmint.com/viewtopic.php?t=150579
http://meier-geinitz.de/sane/gt68xx-backend/
« Last Edit: October 10, 2019, 06:02:20 pm by Mark Greaves (PCNetSpec) »
Offline Melissa
  • Vintage nerd
  • Gender: Female
« Reply #4 on: October 10, 2019, 08:01:44 pm »
Thank you Mark, I'll do that later ( after my mate Dave has been and gone and cleaned my pet rats' cage out lol). i'm on the Chromebook right now, so will have to set up the netbook.
My computers:
Asus Chromebook
Offline emegra
« Reply #5 on: October 28, 2019, 02:48:56 pm »
Hi Melissa
I used to use that scanner which I'm sure is based on a Mustek Bearpaw and in order to get it working I had to place a firmware file at /usr/share/sane/gt68xx,
If so I have a copy of that file if you need it
Offline Melissa
  • Vintage nerd
  • Gender: Female
« Reply #6 on: January 14, 2020, 12:46:17 pm »
Sorry I took an age getting back to you guys; it's been one thing after another.
[email protected] ~ $ sudo apt-get install sane-utils
[sudo] password for matildaw:
Reading package lists... Done
Building dependency tree
  ca-certificates-mono cli-common dcraw fotoxx-common libchamplain-0.12-0
  libchamplain-gtk-0.12-0 libclutter-gtk-1.0-0 libgdiplus libglib2.0-cil
  libgtk2.0-cil libimage-exiftool-perl libmime-charset-perl
  libmono-addins-gui0.2-cil libmono-addins0.2-cil libmono-cairo4.0-cil
  libmono-corlib4.5-cil libmono-i18n-west4.0-cil libmono-i18n4.0-cil
  libmono-posix4.0-cil libmono-security4.0-cil libmono-sharpzip4.84-cil
  libmono-system-configuration4.0-cil libmono-system-core4.0-cil
  libmono-system-drawing4.0-cil libmono-system-security4.0-cil
  libmono-system-xml4.0-cil libmono-system4.0-cil libposix-strptime-perl libsombok3
  libunicode-linebreak-perl linux-headers-4.15.0-43 linux-headers-4.15.0-43-generic
  linux-image-4.15.0-43-generic linux-modules-4.15.0-43-generic
  linux-modules-extra-4.15.0-43-generic mono-4.0-gac mono-gac mono-runtime
  mono-runtime-common mono-runtime-sgen
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  libfile-copy-recursive-perl update-inetd
Suggested packages:
  unpaper
  libfile-copy-recursive-perl sane-utils update-inetd
0 to upgrade, 3 to newly install, 0 to remove and 430 not to upgrade.
Need to get 220 kB of archives.
After this operation, 702 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://gb.archive.ubuntu.com/ubuntu bionic/main amd64 libfile-copy-recursive-perl all 0.40-1 [16.9 kB]
Get:2 http://gb.archive.ubuntu.com/ubuntu bionic/main amd64 update-inetd all 4.44 [18.1 kB]
Get:3 http://gb.archive.ubuntu.com/ubuntu bionic-updates/main amd64 sane-utils amd64 1.0.27-1~experimental3ubuntu2.2 [185 kB]
Fetched 220 kB in 0s (1,518 kB/s)
Preconfiguring packages ...
Selecting previously unselected package libfile-copy-recursive-perl.
(Reading database ... 421576 files and directories currently installed.)
Preparing to unpack .../libfile-copy-recursive-perl_0.40-1_all.deb ...
Unpacking libfile-copy-recursive-perl (0.40-1) ...
Selecting previously unselected package update-inetd.
Preparing to unpack .../update-inetd_4.44_all.deb ...
Unpacking update-inetd (4.44) ...
Selecting previously unselected package sane-utils.
Preparing to unpack .../sane-utils_1.0.27-1~experimental3ubuntu2.2_amd64.deb ...
Unpacking sane-utils (1.0.27-1~experimental3ubuntu2.2) ...
Processing triggers for ureadahead (0.100.0-21) ...
ureadahead will be reprofiled on next reboot
Processing triggers for systemd (237-3ubuntu10.21) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Setting up libfile-copy-recursive-perl (0.40-1) ...
Setting up update-inetd (4.44) ...
Setting up sane-utils (1.0.27-1~experimental3ubuntu2.2) ...
Adding saned group and user...
Adding user saned to group scanner
[email protected] ~ $ scanimage
[gt68xx] Couldn't open firmware file (`/usr/share/sane/gt68xx/PS1fw.usb'): No such file or directory
scanimage: open of device gt68xx:libusb:005:002 failed: Invalid argument
[email protected] ~ $ scanimage -L
device `gt68xx:libusb:005:002' is a Mustek BearPaw 1200 CU flatbed scanner
[email protected] ~ $ sudo scanimage -L
[email protected] ~ $ sane-find-scanner
  # sane-find-scanner will now attempt to detect your scanner. If the
  # result is different from what you expected, first make sure your
  # scanner is powered up and properly connected to your computer.
  # No SCSI scanners found. If you expected something different, make sure that
  # you have loaded a kernel SCSI driver for your SCSI adapter.
could not open USB device 0x04f2/0xb404 at 002:003: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 002:001: Access denied (insufficient permissions)
could not open USB device 0x03eb/0x843d at 004:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 004:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 001:001: Access denied (insufficient permissions)
could not open USB device 0x0000/0x3825 at 003:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 003:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0003 at 006:001: Access denied (insufficient permissions)
found USB scanner (vendor=0x05d8, product=0x4002, chip=GT-6801) at libusb:005:002
could not open USB device 0x1d6b/0x0002 at 005:001: Access denied (insufficient permissions)
  # Your USB scanner was (probably) detected. It may or may not be supported by
  # SANE. Try scanimage -L and read the backend's manpage.
  # Not checking for parallel port scanners.
  # Most Scanners connected to the parallel port or other proprietary ports
  # can't be detected by this program.
  # You may want to run this program as root to find all devices. Once you
  # found the scanner devices, be sure to adjust access permissions as
  # necessary.
[email protected] ~ $ sudo sane-find-scanner
My computers:
Asus Chromebook
Offline Melissa
  • Vintage nerd
  • Gender: Female
« Reply #7 on: January 14, 2020, 12:50:10 pm »
Hi Melissa
Yes that came up in the terminal response to the codes ( that the right word?) that Mark gave me! I'd be very grateful for the file, thank you! Is it easy to install? Weird it worked on the Dell Mint netbook I gave my mate Dave, but doesn't work on this newer Peppermint Asus netbook! I really need a scanner so it'd be great to get it connected.
My computers:
Asus Chromebook
Offline emegra
« Reply #8 on: January 22, 2020, 07:40:59 pm »
Hi Melissa
I'm so sorry I didn't get back to you, I've had so much going on lately
If you still want help getting your scanner working post back and we'll get cracking
Offline Melissa
  • Vintage nerd
  • Gender: Female
« Reply #9 on: January 26, 2020, 11:03:04 pm »
Hi Melissa
No worries Graeme. I know how it is. Was busy myself, then wasn't feeling so well, so not been on here. I sure do want the help thanks. I've a 1938 magazine with fab pictures I want to scan for art projects. Far too precious to cut up! I'll be around Monday afternoon. Does this mean you will give me commands to put into the terminal?
My computers:
Asus Chromebook
Offline emegra
« Reply #10 on: January 27, 2020, 07:02:20 am »
Ok check you private messages I've sent you a link to the firmware file you'll need to get your scanner working, post back here once you have the file downloaded
Offline Melissa
  • Vintage nerd
  • Gender: Female
« Reply #11 on: January 28, 2020, 08:55:54 am »
Have done. Sorry re yesterday, forgot workmen were coming, so didn;t get chance to come on the forum.
My computers:
Asus Chromebook
Offline emegra
« Reply #12 on: January 28, 2020, 06:59:23 pm »
Ok Melissa no problem, you only have 7 days from when I uploaded it before the link expires so please try to download is as soon as you can and let me know when it's done
Offline Melissa
  • Vintage nerd
  • Gender: Female
« Reply #13 on: February 11, 2020, 12:18:14 am »
Sorry Graeme,
I meant to download it and forgot as had a lot going on recently ( work men , rain leaking into kitchen etc). If you can kindly send it to me again I promise I'll do it as soon as possible.
When it's downloaded what is the next step? Commands in the terminal?
My computers:
Asus Chromebook
Offline Melissa
  • Vintage nerd
  • Gender: Female
« Reply #14 on: February 18, 2020, 12:47:52 am »
I'm still looking for help getting my scanner working. I'll keep coming on here to see if anyone replies, many thanks.
My computers:
Asus Chromebook
