Author Topic: xscreensaver não inicia de primeira.  (Read 222647 times)
Offline nogueira13
« on: October 09, 2019, 10:04:05 pm »
Quando eu ligo o computador e dou o boot o xscreensaver não inicia. Daí eu inicio ele via interface gráfica e eu recebo a seguinte mensagem:
Parece que o daemon do xscreensaver não está sendo executado no monitor ".0". Lançá-lo agora?
Aí se eu respondo OK ele inicia e funciona normalmente até o próximo boot.
Como eu poderia corrigir isto?
Offline nogueira13
Re: xscreensaver não inicia de primeira.
« Reply #1 on: October 09, 2019, 10:34:29 pm »
Sorry, I didn't find where to edit the post. So I translate it now to English:
When I turn on the computer and boot it, xscreensaver does not start. Then I start it via GUI and I get the following message:
It looks like the xscreensaver daemon is not running on monitor ".0". Launch it now?
Then if I answer OK it starts and works properly until the next boot.
How could I fix this issue?
« Reply #2 on: October 10, 2019, 05:48:56 pm »
Which distro/version ?
Offline nogueira13
« Reply #3 on: October 10, 2019, 06:37:01 pm »
[email protected]:~$ cat /proc/version
Linux version 5.0.0-31-generic ([email protected]) (gcc version 7.4.0 (Ubuntu 7.4.0-1ubuntu1~18.04.1)) #33~18.04.1-Ubuntu SMP Tue Oct 1 10:20:39 UTC 2019
I installed Ubuntu LTS 18.04
« Reply #4 on: October 10, 2019, 09:20:02 pm »
Open a terminal and run:
gedit ~/.config/autostart/xscreensaver-autostart.desktop
when a blank file opens in the gedit text editor, make it read:
[Desktop Entry]
Type=Application
Name=Xscreensaver Autostart
Comment=Autostart the Xscreensaver Daemon
Exec=xscreensaver -nosplash
Icon=xscreensaver
Terminal=false
SAVE the file and exit the text efditor.
Log off/on (or reboot)  <-- IMPORTANT
Once you've logged back on, test the screensaver
Offline nogueira13
« Reply #5 on: October 15, 2019, 02:56:29 am »
Problem solved. It works now. Thanks a lot!
