Author Topic: Folder permission  (Read 6303 times)
Offline jay
Folder permission
« on: October 19, 2019, 05:05:19 am »
Hi,
Newbie hear!.
can any one please let me know if it is possible to have create folder permission without write permission to a parent directory in linux?
~Jay
Re: Folder permission
« Reply #1 on: October 19, 2019, 05:18:04 pm »
Not 100% sure what you're asking...
If you're asking if it's possible to have a directory WITHOUT write permissions (by a particular users/groups), but have a subdirectory WITH write permissions .. yes.
Try it
mkdir ~/test-parent
mkdir ~/test-parent/test-child
chmod 555 ~/test-parent
Now see if you can create a file or folder in ~/test-parent and ~/test-parent/test-child
Or am I misunderstanding the question ?
You can delete these test folders (and contents) when you're done testing with:
sudo rm -r ~/test-parent
« Last Edit: October 19, 2019, 05:26:29 pm by Mark Greaves (PCNetSpec) »
Offline jay
« Reply #2 on: October 19, 2019, 05:44:48 pm »
Thanks Mark. Below is what i was trying to see if it is possible.
Parent folder: ~/test-parent
I don't want anyone to write to the parent folder, but they can create subfolders and write to those subfolders under test-parent. Please let me know if it is possible in anyways.
~Jay
« Reply #3 on: October 20, 2019, 01:19:32 am »
Well I can't see how they could CREATE subdirectories if they're not allowed to write to the parent directory .. because creating directories requires write permission.
Offline jay
« Reply #4 on: November 02, 2019, 06:23:28 pm »
Thanks Mark. In other words, can only mkdir command is allowed to execute in Parent folder:(~/test-parent) and restrict all other commands just for parent folder?
« Reply #5 on: November 03, 2019, 09:13:04 am »
Sorry I'm having difficulty understanding what you''re asking.
Offline jay
« Reply #6 on: November 11, 2019, 09:25:27 pm »
Mark,
Below is what I want to check.
Parent folder: ~/test-parent (allow only mkdir command in this folder)
child folder:         |_ child-folder-under-parent (allow write and other commands in this folder)
Please let me know if the above setup is possible.
~Jay
« Reply #7 on: November 12, 2019, 01:44:42 am »
No, you could only use mkdir in the parent folder if you had elevated privileges (sudo mkdir).
There's no way (that I know of) to allow writing of folders but not files .. you either have write permission or you don't.
