Author Topic: Gramps 5.1.1  (Read 3443 times)
Offline Goodmans69
Gramps 5.1.1
« on: November 04, 2019, 10:12:14 am »
How do I install Gramps 5.1.1 on Mint 19.2?
Thanks
Goodmans69
Offline emegra
Re: Gramps 5.1.1
« Reply #1 on: November 05, 2019, 09:09:39 am »
The best & easiest way would be to install it from the repos, but if that's not the version you want you can get the latest version (5.1.1) from here
https://github.com/gramps-project/gramps/releases/v5.1.1 near the bottom of the page select gramps_5.1.1-1_all.deb
Remember to make a backup of your existing database first
Good luck
