Author Topic: Cannolo: a tool to shrink, flash and expand disk images on external devices  (Read 2942 times)
Offline jadenfrancis
Cannolo is a simple bash tool that automatically shrinks disk images, flashes them on an external disk/device and expand the primary partition in order to fill the entire disk space.
I developed it in order to easily replicate some disk images/configurations on disks.
Hi, I take it you mean this
https://github.com/WEEE-Open/cannolo
Can you give us a use case please .. I'm struggling to see what (useful) it does that 'dd' won't ?
The Readme.md suggests it'll 'shrink' the image .. how, compression ? .. aren't most ISO's compressed anyway (including being quite slow if lz compression is used).
It also suggests it'll expand the partition to fill the drive .. on a LiveUSB I suppose this would give you room to add a persistence file but only up to 4gb (FAT32 file size limitation), what use would the rest of the drive be ?
I'm probably completely missing the point here, which is why I'm asking :)
