Author Topic: Which processor (solved)  (Read 3037 times)
Offline wishbone
« on: December 03, 2019, 10:38:21 am »
Hi all,
I was wondering which is the best processor AMD Ryzen 5 or Intel I5. I know there`s a load of different ones within each range and can be confusing for the casual user.
For those that don`t do a lot of heavy intensive stuff to the user who just does day to day stuff. I was asked this the other day and was stumped and confused because it`s not my forte!
Just for info, this is mine.
             PPPPPPPPPPPPPP                [email protected]
           PPPPMMMMMMMPPPPPPPPPPP            --------------------------------
         PPPPMMMMMMMMMMPPPPPPPPMMPP          OS: Peppermint 10 Ten x86_64
       PPPPPPPPMMMMMMMPPPPPPPPMMMMMPP        Host: SATELLITE PRO L850-1DP PSKDHE-00H0
     PPPPPPPPPPPPMMMMMMPPPPPPPMMMMMMMPP      Kernel: 5.0.0-37-generic
    PPPPPPPPPPPPMMMMMMMPPPPMPMMMMMMMMMPP     Uptime: 2 hours, 30 mins
   PPMMMMPPPPPPPPPPMMMPPPPPMMMMMMMPMMPPPP    Packages: 1895 (dpkg)
   PMMMMMMMMMMPPPPPPMMPPPPPMMMMMMPPPPPPPP    Shell: bash 4.4.20
  PMMMMMMMMMMMMPPPPPMMPPMPMMPMMPPPPPPPPPPP   Resolution: 1366x768
  PMMMMMMMMMMMMMMMMPPMPMMMPPPPPPPPPPPPPPPP   DE: LXDE
  PMMMPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPMMMMMP   WM: Xfwm4
  PPPPPPPPPPPPPPPPMMMPMPMMMMMMMMMMMMMMMMPP   WM Theme: Peppermint-xfwm4
  PPPPPPPPPPPMMPMMPPPPMMPPPPPMMMMMMMMMMMPP   Theme: Crux [GTK2/3]
   PPPPPPPPMMMMMMPPPPPMMPPPPPPMMMMMMMMMPP    Icons: gnome [GTK2/3]
   PPPPMMPMMMMMMMPPPPPPMMPPPPPPPPPPMMMMPP    Terminal: sakura
    PPMMMMMMMMMPMPPPPMMMMMMPPPPPPPPPPPPP     Terminal Font: Ubuntu Mono,monospace 13
     PPMMMMMMMPPPPPPPMMMMMMPPPPPPPPPPPP      CPU: Intel i3-2328M (4) @ 2.200GHz
       PPMMMMPPPPPPPPPMMMMMMMPPPPPPPP        GPU: Intel 2nd Generation Core Processor
         PPMMPPPPPPPPMMMMMMMMMMPPPP          Memory: 1593MiB / 5847MiB
           PPPPPPPPPPMMMMMMMMPPPP
               PPPPPPPPPPPPPP
Regards
Tony
« Last Edit: December 03, 2019, 08:25:45 pm by wishbone »
Re: Which processor
« Reply #1 on: December 03, 2019, 11:27:29 am »
Impossible to answer I'm afraid, but if the system isn't going to be driven hard in any specific use case they're much of a muchness.
i5 may be better in some single threaded workloads (such as a lot of earlier games).
Ryzen 5 may be better in multithreaded workloads (multithreaded apps or doing lots of things at the same time).
So for your use case .. get whichever is the cheaper ;)
'Bang for the buck' tends to be favouring Ryzen at the moment, but that may not strictly be the case .. specially where you may already have a motherboard and memory that will work with an Intel .. it's more than just about the price of the CPU.
Personally at the moment (and price being pretty equal) I'd probably favour Ryzen, simply because they're being less hard hit by performance penalties from the Spectre/Meltdown mitigation patches (which there's likely to be more of).
« Last Edit: December 03, 2019, 11:33:16 am by Mark Greaves (PCNetSpec) »
Re: Which processor
Offline wishbone
Re: Which processor
« Reply #2 on: December 03, 2019, 08:25:13 pm »
Thank you for the input Mark. Choosing which processor is it seems to me, too complicated but time moves on and so does technology,a bit too fast sometimes.
I`ll mark this as solved and pass on your remarks. Thanks again.
« Last Edit: December 03, 2019, 08:35:31 pm by wishbone »
