Author Topic: SSD (Solved)  (Read 2395 times)
Offline wishbone
SSD (Solved)
« on: December 03, 2019, 08:34:30 pm »
After reading about the speed and durability of SSD`s over their SATA HDD`s cousins I thought it would be a good idea to check them out. I went onto Crucial`s website and tried to input my laptop without success. After several attempts I decided to contact them and received a reply that one cannot be fitted into my Satellite Pro L850 1DP but I can get an external one. I can see the advantage of an external one but that`s not what I want, anyway it is what it is!
Regards
Tony
« Last Edit: December 04, 2019, 11:47:29 am by wishbone »
Re: SSD
« Reply #1 on: December 03, 2019, 10:07:19 pm »
Well I have no idea which idiot you talked to at Crucial but he needs to be sent back to his previous floor mopping job at McDonald's .. If your Satellite Pro L850 is the same as the one in this video (?):-
https://www.youtube.com/watch?v=y1SevmqwI_A
then it most certainly CAN take an SATA3 SSD
as confirmed in this video
https://www.youtube.com/watch?v=qap85AuRfWU
in fact it's an easier swap out than most newer laptops.
Just get any SATA3 (sometimes written as SATA-III or similar) SSD .. if unsure, find one you like and post a link back here and I'll tell you if it's compatible.
If you're quick and the Black Friday / Cyber Monday deals are still on, here's as good a place to start as any
https://www.ebuyer.com/blackfriday/storage/ssd
just make sure it's an SATA SSD and not M.2 or NVMe.
« Last Edit: December 03, 2019, 10:29:06 pm by Mark Greaves (PCNetSpec) »
Offline wishbone
Re: SSD
« Reply #2 on: December 04, 2019, 11:47:10 am »
Mark that is brilliant, you are a genius (and I`m not the only one to think that). The videos are pretty much the same as mine so I shall go ahead and get one.
Thank you ever so much,I will mark this as solved. 8)
Offline wishbone
Re: SSD (Solved)
« Reply #3 on: December 04, 2019, 11:51:12 am »
Re: SSD (Solved)
« Reply #4 on: December 05, 2019, 12:23:42 pm »
Yep, that'll do the trick Tony :)
Offline wishbone
Re: SSD (Solved)
« Reply #5 on: December 05, 2019, 07:18:03 pm »
Cheers Mark, have ordered it pronto. Thank you again.
