Author Topic: New Computer Problems With Mint 19.3  (Read 718 times)
Offline ahead
  • Full Member
« on: March 09, 2020, 11:01:02 am »
Bit of help needed please. I have been using Mint  for about 10 years now. I recently bought a new laptop and installed 19.3 over the Win 10 and I can't access the internet using wifi, however, Xubuntu connects with no problem. There are other issues like screen backlight commands won't work and all the desk top icons and fonts are very small, though these are low priority at the moment. I like the Xubuntu but I would like to use 19.3 as an option - any ideas Please?
I have taken this s/shot if it helps:
graham@graham-NL40-50CU:~$ inxi -Fx
System:    Host: graham-NL40-50CU Kernel: 5.3.0-40-generic x86_64
           bits: 64 gcc: 7.4.0
           Desktop: Xfce 4.12.3 (Gtk 2.24.31) Distro: Ubuntu 18.04.4 LTS
Machine:   Device: laptop System: Notebook product: NL40_50CU serial: N/A
           Mobo: Notebook model: NL40_50CU serial: N/A
           UEFI: INSYDE v: 1.07.06TPCS date: 09/14/2019
Battery    BAT0: charge: 16.2 Wh 42.3% condition: 38.3/36.2 Wh (106%)
           model: Notebook BAT status: Discharging
CPU:       Quad core Intel Core i5-10210U (-MT-MCP-)
           arch: Kaby Lake rev.12 cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 16799
           clock speeds: max: 4200 MHz 1: 800 MHz 2: 833 MHz 3: 852 MHz
           4: 890 MHz 5: 835 MHz 6: 837 MHz 7: 847 MHz 8: 830 MHz
Graphics:  Card: Intel Device 9b41 bus-ID: 00:02.0
           Display Server: x11 (X.Org 1.20.5 )
           drivers: modesetting (unloaded: fbdev,vesa)
           Resolution: 1920x1080@60.16hz
           OpenGL: renderer: Mesa DRI Intel UHD Graphics (Comet Lake 3x8 GT2)
           version: 4.5 Mesa 19.2.8 Direct Render: Yes
Audio:     Card Intel Device 02c8 driver: snd_hda_intel bus-ID: 00:1f.3
           Sound: Advanced Linux Sound Architecture v: k5.3.0-40-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8169 port: 4000 bus-ID: 01:00.1
           IF: enp1s0f1 state: down mac: 80:fa:5b:76:35:63
           Card-2: Intel Device 2723 driver: iwlwifi bus-ID: 06:00.0
           IF: wlp6s0 state: up speed: N/A duplex: N/A mac: f8:e4:e3:23:3e:ee
Drives:    HDD Total Size: 128.0GB (6.7% used)
           ID-1: /dev/sda model: 128GB_PCS_2.5"_S size: 128.0GB
Partition: ID-1: / size: 117G used: 8.0G (8%) fs: ext4 dev: /dev/sda2
Sensors:   System Temperatures: cpu: 39.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 238 Uptime: 10 min Memory: 954.3/7654.5MB
           Init: systemd runlevel: 5 Gcc sys: N/A
           Client: Shell (bash 4.4.201) inxi: 2.3.56
Though I use Linux I am not very tech savvy so a simple explanation would be appreciated! Many thanks.
P.S. Ubuntu also will not auto connect either.
Re: New Computer Problems With Mint 19.3
« Reply #1 on: March 09, 2020, 02:26:40 pm »
Hi Graham.
Try starting a terminal session and entering:
iwlist scan
This should list all the nearby routers.  If your router is listed with a decent signal then that should provide a clue.
If it doesn't list any routers then that provides an even bigger clue.
« Last Edit: March 09, 2020, 03:12:27 pm by Keith »
Offline ahead
  • Full Member
« Reply #2 on: March 09, 2020, 03:46:43 pm »
Thanks Keith - This is the result, doesn't mean a lot to me I'm afraid, though the number of sig strength bars is only 2. Thanks, Graham.
graham@graham-NL40-50CU:~$ iwlist scan
wlp6s0    Scan completed :
          Cell 01 - Address: 90:72:82:78:97:65
                    Channel:48
                    Frequency:5.24 GHz (Channel 48)
                    Quality=40/70  Signal level=-70 dBm
                    Encryption key:on
                    ESSID:"PLUSNET-3SJW"
                    Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s
                              36 Mb/s; 48 Mb/s; 54 Mb/s
                    Mode:Master
                    Extra:tsf=000010fc368612fe
                    Extra: Last beacon: 166888ms ago
                    IE: Unknown: 000C504C55534E45542D33534A57
                    IE: Unknown: 01088C129824B048606C
                    IE: Unknown: 030130
                    IE: Unknown: 073C4742202401142801142C01143001143401143801143C011440011464011B68011B6C011B70011B74011B78011B7C011B80011B84011B88011B8C011B
                    IE: Unknown: 200103
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                    IE: Unknown: 2D1A6F111BFFFFFF0000000000000000008000000000000000000000
                    IE: Unknown: 3D16300F0000000000000000000000000000000000000000
                    IE: Unknown: 7F080000000000000040
                    IE: Unknown: BF0C32018033CAFF0000EAFF0000
                    IE: Unknown: C005012A00FCFF
                    IE: Unknown: C30402D8D8D8
                    IE: Unknown: DD8D0050F204104A000110104400010210570001001041000100103B000103104700101B4269FD4E2A5C58B7E105367C37630510210002425410230005487562203510240009425420487562203541104200122B3038313434312B4E5136303431363539381054000800060050F20400011011000F506C75736E657420487562204F6E65100800020084103C000102
enp1s0f1  Interface doesn't support scanning.
« Reply #3 on: March 09, 2020, 03:59:54 pm »
I know I'm being pedantic, but can you confirm that "PLUSNET-3SJW" is your router?  And did you get any others?
The signal quality of 40/70 should be fine but the signal strength of -70dBm is tiny.  Mine is -47dBm  (200 times bigger).  A signal strength of -70dBm means 10^-10Watts.
On the other hand, two signal bars ought to be readable.
Can you decrease the distance between PC and router?
Are your Ubuntu 18 & Xubuntu machines at the same distance from the router as your Mint laptop?
Can you use Ethernet?
« Last Edit: March 09, 2020, 04:04:26 pm by Keith »
Offline ahead
  • Full Member
« Reply #4 on: March 09, 2020, 05:22:03 pm »
Hi Keith
This the result from my old comp, Mint 19.3, sitting right next to my new comp - different result. Signal strength showing 5 bars (86%).  Yes it is my router and the wireless  desktop, win 10 has a good signal. So it looks like the new comp is lacking signal strength for some reason? Too far away to use an ethernet.
graham@graham-HP-ProBook-455-G2:~$ iwlist scan
enp1s0    Interface doesn't support scanning.
wlo1      Scan completed :
          Cell 01 - Address: 90:72:82:78:97:64
                    Channel:11
                    Quality=70/70  Signal level=-32 dBm
                    Encryption key:on
                    Mode:Master
                    Extra:tsf=000005c2a2800317
                    Extra: Last beacon: 32496ms ago
                    IE: Unknown: 03010B
                    IE: Unknown: 0706474220010D14
                    IE: Unknown: 2A0100
                        Group Cipher : CCMP
                    IE: Unknown: 32043048606C
                    IE: Unknown: 2D1AAC011BFFFF000000000000000000008000000000000000000000
                    IE: Unknown: 3D160B080400000000000000000000000000000000000000
                    IE: Unknown: 7F080100000000000040
                    IE: Unknown: DD8D0050F204104A000110104400010210570001001041000100103B000103104700101B4269FD4E2A5C58B7E105367C37630510210002425410230005487562203510240009425420487562203541104200122B3038313434312B4E5136303431363539381054000800060050F20400011011000F506C75736E657420487562204F6E65100800020084103C000101
« Reply #5 on: March 09, 2020, 05:47:38 pm »
Yes, it certainly looks like a problem with your new laptop.  The specifications of the machines and the reports on the web (https://browser.geekbench.com/v4/cpu/15197553) look very good to me (although I'm no expert!), so it's very disappointing to have such poor wifi reception.
If no-one else has any advice to give then a last-ditch solution might be to replace the wifi receiver.  Not too expensive but a pain to do - I've done it once.  If you decide to go that route, then you'll probably find a YouTube demonstration of how to do it.  What's the Laptop make, Graham?
Offline ahead
  • Full Member
« Reply #6 on: March 09, 2020, 06:03:59 pm »
Thanks Keith, it's an UltraNote series 15.6 Matte made by PC Specialist in Wakefield. I suspect it is 'tuned' to Win 10 so I think I shall have to have a word with them. As I said Xubuntu is working ok on it but I may have to reconcile it by reloading win 10.....hmmmm.
« Reply #7 on: March 09, 2020, 06:31:47 pm »
Ah..... if Xubuntu wifi is working on it (I thought Xubuntu was on a different machine) then the problem does not lie with the wifi receiver, but with the Mint installation.
What is the output from the iwlist scan command in Xubuntu?
Offline ahead
  • Full Member
« Reply #8 on: March 10, 2020, 08:42:47 am »
Ok, the first iwlist scan output was from Xubuntu on my new comp, the second iwlist scan was from Mint 19.3 on my old laptop situated next to the new machine. It seems that this new laptop has been built to be 'compatible' to ms win only - could it be a driver problem?
EDIT: The output of iwlist scan on Mint 19.3 running of a USB stick on the new machine says:
empls0fl   Interface doesn't support scanning
« Last Edit: March 10, 2020, 08:54:31 am by ahead »
« Reply #9 on: March 10, 2020, 10:00:11 am »
Sorry;  I am very confused.
You say that "the first iwlist scan output was from Xubuntu on my new comp" but your first post says "I recently bought a new laptop and installed (Mint) 19.3 over the Win 10".
Can we start again?
Please post the output from the following commands on  just your new machine that you want to have Mint 19 running on:
inxi -Fx
iwlist scan
Offline ahead
  • Full Member
« Reply #10 on: March 10, 2020, 10:34:43 am »
Apologies for the confusion, I put 19.3 on the new computer then I put Xubuntu over the 19.3 when I found that Icould not connect the wifi with the 19.3.I also have 19.3 on my old computer.
Here are the outputs you asked for:
           bits: 64 gcc: 7.4.0
Battery    BAT0: charge: 36.0 Wh 92.6% condition: 38.9/36.2 Wh (107%)
           model: Notebook BAT status: Charging
           clock speeds: max: 4200 MHz 1: 1217 MHz 2: 3094 MHz 3: 3057 MHz
           4: 3002 MHz 5: 2433 MHz 6: 2724 MHz 7: 2610 MHz 8: 2666 MHz
Partition: ID-1: / size: 117G used: 8.1G (8%) fs: ext4 dev: /dev/sda2
Sensors:   System Temperatures: cpu: 42.0C mobo: N/A
Info:      Processes: 242 Uptime: 18 min Memory: 959.8/7654.5MB
AND:
                    Channel:11
                    Quality=45/70  Signal level=-65 dBm
                    Encryption key:on
                    Mode:Master
                    Extra:tsf=000005d123c2ddf1
                    Extra: Last beacon: 626640ms ago
                    IE: Unknown: 03010B
                    IE: Unknown: 2A0100
                        Group Cipher : CCMP
Hope this is ok. Graham
« Reply #11 on: March 10, 2020, 10:39:08 am »
So now you have Xubuntu on the new computer that you have just inxi'd?
....and Mint 19.3 on your old computer?
Just checking as I'm a bit slow-witted!
Offline ahead
  • Full Member
« Reply #12 on: March 10, 2020, 11:15:40 am »
Yes, as I said the only Linux that works on the new comp is Xubuntu, both the last outputs, inxi and iwlist, were from the new comp+Xubuntu.
Sorry again for all the confusion!
« Reply #13 on: March 10, 2020, 11:48:18 am »
That's OK.
The disk of your new computer has a single partition that occupies almost the whole drive, so I doubt that there are any Windows influences - and in any case that would be unlikely to affect the wifi and backlight, etc.  The very low wifi signal level does indicate a potential problem but you say Xubuntu does connect OK which is odd.
Have you tried a re-install of Mint19?  If you get the same result, then perhaps try Peppermint 10, also based on Ubuntu, for comparison.  https://peppermintos.com/
Offline ahead
  • Full Member
« Reply #14 on: March 10, 2020, 11:57:08 am »
Ok, I'll try that - talk to you later!
