Author Topic: Help Required to Restore Ubuntu Dual Boot Option  (Read 4354 times)
Offline ivatt1940
« on: April 17, 2020, 04:05:57 pm »
I am a Ubuntu novice having only got involved recently in an attempt to make x-plane 11 run quicker.
Whilst investigating some software the other day I annoyingly and mistakenly changed the Grub2 boot options for my PC so that my PC boot at all, it just gave a grub error (can't remember what it said).
After some time I managed to get it back to the point where I can boot into W10 but my Ubuntu boot option (through Windows 10 MBR) doesn't exist or rather points to a non existent file.
EasyBCD shows the the boot options as below
There are a total of 2 entries listed in the bootloader.
Default: Windows 10
Timeout: 17 seconds
Boot Drive: D:\
Entry #1
BCD ID: {current}
Drive: C:\
Bootloader Path: \WINDOWS\system32\winload.exe
Entry #2
Name: Grub 2 For Windows
BCD ID: {a0ffb549-1824-11e9-8ad8-8236e31b4d39}
Drive: C:\
Bootloader Path: \grub2\g2bootmgr\gnugrub.kernel.bios
Having messed things up yesterday I am loathe just to go blindly ahead in case I mess things up agaiin.
I would appreciate help in getting my Ubuntu boot option back.
I am due a hardware upgrade next week and intend to dual boot Ubuntu & W10 from the same SSD. I don't want to reinstall Ubuntu as I have it setup to use with x-plane 11 and it took some effort to get it working properly thanks to x-plane 11 Ubuntu users help.
At a least resort I need at least to be able to access Ubuntu as I believe there is a way to copy over the necessary files to the new install. I have a Ubuntu CD which I have used before to access Ubuntu without installing.
I have posted this question on another site previously
Thanks
Offline Rich J
  • Still a Linux Luvvie!
Re: Help Required to Restore Ubuntu Dual Boot Option
« Reply #1 on: April 18, 2020, 10:14:03 am »
Default: Windows 10
Timeout: 17 seconds
Boot Drive: D:\
Entry #1
BCD ID: {current}
Drive: C:\
Entry #2
Drive: C:\
Thanks
Hi - and welcome to the Forums.
Can you boot from your Ubuntu CD and open a terminal?  Enter these commands - one at a time!
sudo fdisk -l
sudo blkid
Press Enter after each command and post the results back here.
NB: You can copy/paste the commands into terminal and likewise the results into your reply.
