Author Topic: Linux Lite 4.8 on VM Won't Update.  (Read 640 times)
Offline MattC
« on: May 30, 2020, 09:27:47 pm »
Hi.
Just installed Linux Lite 4.8 on a vitual machine (VB) but it won't update.  It produces an error log.  (This is hand copied as the shared clipboard does not seem to working either - which is another issue.  However, the bad grammar is in the original  ???)
Install Updates could not be successfully download and install available updates.
E:Could not get lock /var/lib/dpkg/lock-frontend - open(11:Resource temporarily unavailable)
E:Unable to aquire the dpkg front end lock (/var/lib/dpkg/lock-frontend), is another process using it?
Matt
Re: Linux Lite 4.8 on VM Won't Update.
« Reply #1 on: June 01, 2020, 10:03:18 am »
Online Keith
« Reply #2 on: June 01, 2020, 04:28:49 pm »
...... and you may find more extensive info here, too: https://itsfoss.com/could-not-get-lock-error/
