Author Topic: Motherboard and Buster  (Read 700 times)
Offline freelancehelp
« on: June 03, 2020, 03:42:09 pm »
Various reports have led me to believe that third generation AMD Ryzen CPUs will work okay with the stable release
of Buster, so I am trying to arrange the build of a desktop with the stable release of Buster as the operating system.
I aim to use the AMD Ryzen 5 3600 as the CPU and the MSI X570-A PRO as the motherboard.
However i was recently given the following information by an MSI user about the MSI X570-A PRO :-
"See the following link :-
https://community.amd.com/servlet/jiveservlet/downloadimage/2-2975897-167843/MSI_X570-PRO.png. png
As you can see, according to the above link, the BIOS offered by MSI is still Beta, not the final version of
AGESA 1.0.0.5
AGESA 1.0.0.6 is usually the final version that ends the cycle for every Ryzen generation so its a reference
approach has been so for 1st and 2nd Ryzen generations) offering stability regardless of using 2000 or
3000 series.
Also the BIOS should be flashed to AGESA 1.0.0.6 end of 2018 by the seller before the computer is bought"
I have further been informed that the X570 board and Ryzen 3000 series came out about the same time as
the stable release of Buster I.e. July 2019
As mentioned at the beginning of this email, various reports have convinced me that the Ryzen 5 3600 CPU
will work okay with the stable release of Buster. But the MSI X570-A PRO motherboard and its BIOS may have
a serious issue with Buster. Indeed the motherboard may fail to boot.
So I am rather concerned about the stability offered by the BIOS on the MSI X570-A PRO motherboard.
Offline Mad Penguin
Re: Motherboard and Buster
« Reply #1 on: June 15, 2020, 09:52:44 pm »
If it helps I've recently upgraded to a 3rd Gen Ryzen 5 2600 using a ASUS ROG Strix B450-F motherboard, indeed I've upgraded two boxes, one with 16Gb and other other 32. Both have been running well with Ubuntu 19.10, one XUbuntu and the other KUbuntu - not had any problems with either of them. Also using a WD Blue SN550 500GB High-Performance M.2 Pcie NVMe SSD, which is a bit of an eye opener .. I've not seen an SSD hit 2G/sec before (!)
