Author Topic: CD Ripping  (Read 3530 times)
Offline Melissa
  • Vintage nerd
  • Gender: Female
CD Ripping
« on: July 27, 2020, 04:57:03 pm »
Guys what programme would you recommend for CD ripping? I want to put mp3 music files off my netbook onto CDS. I bought a retro radio CD player ( that looks 1930s) to play old music on but I can't get  my data stick which has mp3s to play on it, but CDs work great on it.
I got it second hand off Ebay and the seller said the mp3 worked for her, so I dunno why it won't work for me.
But anyway CDs are probably better as having a data stick sticking out of the socket ruins the illusion of listening to an old wireless!
I'll have to get an external CD drive because my netbook hasn't got one.
I have Audacity on my netbook for music files, but don't know if it rips CDs as well.
My computers:
Acer Chromebook
Asus notebook x102B, running on Peppermint 9.
Re: CD Ripping
« Reply #1 on: July 27, 2020, 05:09:26 pm »
Hi Melissa.
If you have the MP3 files on your netbook, then you have already ripped them, so simply copying them to a CD (like to a USB stick) might work, unless the CD player expects only CD-formatted files.  Copying them from netbook to a CD will be fine to play them on a PC but not sure about a CD player.
Other, more experienced, Forum members will be able to provide better advice.
Re: CD Ripping
Offline DavidMcCann
Re: CD Ripping
« Reply #2 on: July 28, 2020, 04:05:40 pm »
CD players normally expect wav files, not mp3, so you need to convert them before burning the disk. Here's a tutorial:
https://www.linux.org/threads/making-music-audio-cds.10240/
Offline Melissa
  • Vintage nerd
  • Gender: Female
Re: CD Ripping
« Reply #3 on: July 29, 2020, 01:27:40 am »
Thanks guys. I used the wrong term- yes got lots of mp3s. I know how to convert them to wav. I didn't know that CDs should be wav; that's useful to know.
What programme should I use to put the files onto CDs once I get an external CD drive?
My computers:
Acer Chromebook
Offline DavidMcCann
Re: CD Ripping
« Reply #4 on: July 29, 2020, 04:51:17 pm »
As that tutorial says, whatever disk burner you get with your distro should do the job. I have a thing called xfburn which starts by offering 4 options: blank disk, create data disk, create installation disk, and create audio disk. Simple!
Re: CD Ripping
Offline Melissa
  • Vintage nerd
  • Gender: Female
Re: CD Ripping
« Reply #5 on: July 29, 2020, 10:58:25 pm »
Just had a quick look at the tutorial and then saved it to my Pocket. I  now remember using Brasero a few years ago on an earlier Peppermint distro with an old laptop. It worked fine.
I suppose I'd have to find it in the package manager?
My computers:
Acer Chromebook
Re: CD Ripping
« Reply #6 on: July 30, 2020, 11:45:56 am »
Hello Melissa.
You will find Brasero in System-Tools/Software, which is generally easier to use than Package Manager.
Offline Melissa
  • Vintage nerd
  • Gender: Female
Re: CD Ripping
« Reply #7 on: August 07, 2020, 05:21:46 pm »
Thanks Keith. I will be getting the CD/DVD drive next Friday. I'll let you know how I get on then!
My computers:
Acer Chromebook
Offline Melissa
  • Vintage nerd
  • Gender: Female
Re: CD Ripping
« Reply #8 on: August 20, 2020, 06:52:11 pm »
Guys there's no CD ripping software anywhere on my netbook. This includes both the software manager and the package managers!
I'm on Peppermint 9 distro. Brasero or Asunder should be there but they are not.
I'm right frustrated! I am dying to rip some CDS.
My computers:
Acer Chromebook
Re: CD Ripping
Re: CD Ripping
« Reply #9 on: August 20, 2020, 06:59:13 pm »
Hello Melissa.
Try:
sudo apt update
sudo apt install brasero
Offline Melissa
  • Vintage nerd
  • Gender: Female
Re: CD Ripping
« Reply #10 on: August 20, 2020, 07:12:21 pm »
Thanks Keith- there seems to be some problem with all that---
[email protected] ~ $ sudo apt update
[sudo] password for matildaw:
Hit:1 http://gb.archive.ubuntu.com/ubuntu bionic InRelease
Hit:4 http://ppa.launchpad.net/peppermintos/p9-release/ubuntu bionic InRelease
Hit:5 http://ppa.launchpad.net/peppermintos/p9-respin/ubuntu bionic InRelease
Get:2 http://gb.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Hit:6 http://dl.google.com/linux/chrome/deb stable InRelease
Get:3 http://gb.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
Get:7 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Get:8 http://archive.canonical.com/ubuntu bionic InRelease [10.2 kB]
Ign:9 http://gb.archive.ubuntu.com/ubuntu bionic/main amd64 Packages
Ign:10 http://gb.archive.ubuntu.com/ubuntu bionic/main i386 Packages
Ign:11 http://gb.archive.ubuntu.com/ubuntu bionic/main Translation-en
Get:9 http://gb.archive.ubuntu.com/ubuntu bionic/main amd64 Packages [5,280 B]
Err:9 http://gb.archive.ubuntu.com/ubuntu bionic/main amd64 Packages
  File has unexpected size (1019132 != 5280). Mirror sync in progress? [IP: 91.189.88.152 80]
  Hashes of expected file:
   - Filesize:5280 [weak]
   - SHA256:d060a2737854799fbd8d81bc94a73592358437982d97afba1e94baf436d4ebaa
   - SHA1:a19caf819fed97263a91e94b5c1616f0183ed688 [weak]
   - MD5Sum:9345d1ab6c078754ab576c9c736e8f7e [weak]
  Release file created at: Sun, 08 Sep 2019 14:25:06 +0000
Get:10 http://gb.archive.ubuntu.com/ubuntu bionic/main i386 Packages [5,268 B]
Err:10 http://gb.archive.ubuntu.com/ubuntu bionic/main i386 Packages
Get:11 http://gb.archive.ubuntu.com/ubuntu bionic/main Translation-en [2,600 B]
Err:11 http://gb.archive.ubuntu.com/ubuntu bionic/main Translation-en
E: Repository 'http://gb.archive.ubuntu.com/ubuntu bionic-updates InRelease' changed its 'Origin' value from 'LP-PPA-peppermintos-p9-respin' to 'Ubuntu'
E: Repository 'http://gb.archive.ubuntu.com/ubuntu bionic-updates InRelease' changed its 'Label' value from 'Peppermint 9 Respin' to 'Ubuntu'
E: Repository 'http://gb.archive.ubuntu.com/ubuntu bionic-updates InRelease' changed its 'Suite' value from 'bionic' to 'bionic-updates'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
Do you want to accept these changes and continue updating from this repository? [y/N] y
Get:12 http://gb.archive.ubuntu.com/ubuntu bionic-updates/main i386 Packages [727 kB]
Get:13 http://gb.archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [1,038 kB]
E: Repository 'http://gb.archive.ubuntu.com/ubuntu bionic-backports InRelease' changed its 'Origin' value from 'LP-PPA-peppermintos-p9-respin' to 'Ubuntu'
E: Repository 'http://gb.archive.ubuntu.com/ubuntu bionic-backports InRelease' changed its 'Label' value from 'Peppermint 9 Respin' to 'Ubuntu'
E: Repository 'http://gb.archive.ubuntu.com/ubuntu bionic-backports InRelease' changed its 'Suite' value from 'bionic' to 'bionic-backports'
E: Repository 'http://gb.archive.ubuntu.com/ubuntu bionic-backports InRelease' changed its default priority for apt_preferences(5) from 500 to 100.
Get:14 http://gb.archive.ubuntu.com/ubuntu bionic-updates/main Translation-en [348 kB]
Get:15 http://gb.archive.ubuntu.com/ubuntu bionic-updates/main amd64 DEP-11 Metadata [295 kB]
Get:16 http://gb.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 48x48 Icons [81.9 kB]
Get:17 http://gb.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 64x64 Icons [157 kB]
Get:18 http://gb.archive.ubuntu.com/ubuntu bionic-updates/restricted amd64 Packages [85.5 kB]
Get:19 http://gb.archive.ubuntu.com/ubuntu bionic-updates/restricted i386 Packages [11.0 kB]
Get:20 http://gb.archive.ubuntu.com/ubuntu bionic-updates/restricted Translation-en [18.8 kB]
Get:21 http://gb.archive.ubuntu.com/ubuntu bionic-updates/universe i386 Packages [1,028 kB]
Get:22 http://gb.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [1,100 kB]
Get:23 http://gb.archive.ubuntu.com/ubuntu bionic-updates/universe Translation-en [342 kB]
Get:24 http://gb.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 DEP-11 Metadata [285 kB]
Get:25 http://gb.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 48x48 Icons [214 kB]
Get:26 http://gb.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 64x64 Icons [464 kB]
Get:27 http://gb.archive.ubuntu.com/ubuntu bionic-updates/multiverse i386 Packages [8,512 B]
Get:28 http://gb.archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 Packages [19.4 kB]
Get:29 http://gb.archive.ubuntu.com/ubuntu bionic-updates/multiverse Translation-en [6,740 B]
Get:30 http://gb.archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 DEP-11 Metadata [2,468 B]
Get:31 http://gb.archive.ubuntu.com/ubuntu bionic-updates/multiverse DEP-11 48x48 Icons [29 B]
Get:32 http://gb.archive.ubuntu.com/ubuntu bionic-updates/multiverse DEP-11 64x64 Icons [2,638 B]
Get:33 http://gb.archive.ubuntu.com/ubuntu bionic-backports/main i386 Packages [7,508 B]
Get:34 http://gb.archive.ubuntu.com/ubuntu bionic-backports/main amd64 Packages [7,516 B]
Get:35 http://gb.archive.ubuntu.com/ubuntu bionic-backports/main Translation-en [4,764 B]
Get:36 http://gb.archive.ubuntu.com/ubuntu bionic-backports/universe amd64 Packages [7,736 B]
Get:37 http://gb.archive.ubuntu.com/ubuntu bionic-backports/universe i386 Packages [7,724 B]
Get:38 http://gb.archive.ubuntu.com/ubuntu bionic-backports/universe Translation-en [4,588 B]
E: Repository 'http://security.ubuntu.com/ubuntu bionic-security InRelease' changed its 'Origin' value from 'LP-PPA-peppermintos-p9-respin' to 'Ubuntu'
E: Repository 'http://security.ubuntu.com/ubuntu bionic-security InRelease' changed its 'Label' value from 'Peppermint 9 Respin' to 'Ubuntu'
E: Repository 'http://security.ubuntu.com/ubuntu bionic-security InRelease' changed its 'Suite' value from 'bionic' to 'bionic-security'
Get:39 http://gb.archive.ubuntu.com/ubuntu bionic-backports/universe amd64 DEP-11 Metadata [9,288 B]
Get:40 http://gb.archive.ubuntu.com/ubuntu bionic-backports/universe DEP-11 48x48 Icons [2,809 B]
Get:41 http://gb.archive.ubuntu.com/ubuntu bionic-backports/universe DEP-11 64x64 Icons [3,943 B]
Get:42 http://security.ubuntu.com/ubuntu bionic-security/main i386 Packages [519 kB]
Get:43 http://security.ubuntu.com/ubuntu bionic-security/main amd64 Packages [813 kB]
Get:44 http://security.ubuntu.com/ubuntu bionic-security/main Translation-en [255 kB]
Get:45 http://security.ubuntu.com/ubuntu bionic-security/main amd64 DEP-11 Metadata [48.8 kB]
E: Repository 'http://archive.canonical.com/ubuntu bionic InRelease' changed its 'Origin' value from 'LP-PPA-peppermintos-p9-respin' to 'Canonical'
E: Repository 'http://archive.canonical.com/ubuntu bionic InRelease' changed its 'Label' value from 'Peppermint 9 Respin' to 'Partner archive'
Get:46 http://security.ubuntu.com/ubuntu bionic-security/main DEP-11 48x48 Icons [28.4 kB]
Get:47 http://security.ubuntu.com/ubuntu bionic-security/main DEP-11 64x64 Icons [62.4 kB]
Get:48 http://security.ubuntu.com/ubuntu bionic-security/restricted i386 Packages [6,412 B]
Get:49 http://security.ubuntu.com/ubuntu bionic-security/restricted amd64 Packages [76.4 kB]
Get:50 http://security.ubuntu.com/ubuntu bionic-security/restricted Translation-en [16.7 kB]
Get:51 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages [695 kB]
Get:52 http://security.ubuntu.com/ubuntu bionic-security/universe i386 Packages [635 kB]
Get:53 http://security.ubuntu.com/ubuntu bionic-security/universe Translation-en [230 kB]
Get:54 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 DEP-11 Metadata [55.9 kB]
Get:55 http://archive.canonical.com/ubuntu bionic/partner amd64 Packages [2,288 B]
Get:56 http://security.ubuntu.com/ubuntu bionic-security/universe DEP-11 48x48 Icons [19.8 kB]
Get:57 http://archive.canonical.com/ubuntu bionic/partner i386 Packages [2,292 B]
Get:58 http://security.ubuntu.com/ubuntu bionic-security/universe DEP-11 64x64 Icons [109 kB]
Get:59 http://archive.canonical.com/ubuntu bionic/partner Translation-en [1,332 B]
Get:60 http://security.ubuntu.com/ubuntu bionic-security/multiverse amd64 Packages [8,312 B]
Get:61 http://security.ubuntu.com/ubuntu bionic-security/multiverse i386 Packages [3,884 B]
Get:62 http://security.ubuntu.com/ubuntu bionic-security/multiverse Translation-en [2,880 B]
Get:63 http://security.ubuntu.com/ubuntu bionic-security/multiverse amd64 DEP-11 Metadata [2,464 B]
Get:64 http://security.ubuntu.com/ubuntu bionic-security/multiverse DEP-11 48x48 Icons [29 B]
Get:65 http://security.ubuntu.com/ubuntu bionic-security/multiverse DEP-11 64x64 Icons [2,638 B]
Fetched 10.1 MB in 36s (285 kB/s)
Reading package lists... Done
W: Skipping acquire of configured file 'restricted/binary-amd64/Packages' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'restricted' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'restricted/binary-i386/Packages' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'restricted' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'restricted/i18n/Translation-en_GB' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'restricted' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'restricted/i18n/Translation-en' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'restricted' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'restricted/dep11/Components-amd64.yml' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'restricted' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'restricted/dep11/icons-48x48.tar' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'restricted' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'restricted/dep11/icons-64x64.tar' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'restricted' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'restricted/cnf/Commands-amd64' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'restricted' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/binary-i386/Packages' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/binary-amd64/Packages' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/i18n/Translation-en_GB' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/i18n/Translation-en' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/dep11/Components-amd64.yml' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/dep11/icons-48x48.tar' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/dep11/icons-64x64.tar' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/cnf/Commands-amd64' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'multiverse/binary-i386/Packages' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'multiverse' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'multiverse/binary-amd64/Packages' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'multiverse' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'multiverse/i18n/Translation-en_GB' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'multiverse' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'multiverse/i18n/Translation-en' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'multiverse' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'multiverse/dep11/Components-amd64.yml' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'multiverse' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'multiverse/dep11/icons-48x48.tar' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'multiverse' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'multiverse/dep11/icons-64x64.tar' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'multiverse' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'multiverse/cnf/Commands-amd64' as repository 'http://gb.archive.ubuntu.com/ubuntu bionic InRelease' doesn't have the component 'multiverse' (component misspelt in sources.list?)
W: Conflicting distribution: http://ppa.launchpad.net/peppermintos/p9-release/ubuntu bionic InRelease (expected bionic but got stable)
N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'http://ppa.launchpad.net/peppermintos/p9-release/ubuntu bionic InRelease' doesn't support architecture 'i386'
E: Failed to fetch http://gb.archive.ubuntu.com/ubuntu/dists/bionic/main/binary-amd64/Packages.xz  File has unexpected size (1019132 != 5280). Mirror sync in progress? [IP: 91.189.88.152 80]
E: Failed to fetch http://gb.archive.ubuntu.com/ubuntu/dists/bionic/main/binary-i386/Packages.xz
E: Failed to fetch http://gb.archive.ubuntu.com/ubuntu/dists/bionic/main/i18n/Translation-en.xz
E: Some index files failed to download. They have been ignored, or old ones used instead.
[email protected] ~ $ sudo apt install brasero
Building dependency tree
Package brasero is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  nautilus-extension-gnome-terminal:i386 nautilus-extension-gnome-terminal
E: Package 'brasero' has no installation candidate
My computers:
Acer Chromebook
Re: CD Ripping
« Reply #11 on: August 20, 2020, 08:33:50 pm »
Hmmm!
Try the same thing with Asunder:
sudo apt install asunder
Worth a try.
Offline Melissa
  • Vintage nerd
  • Gender: Female
Re: CD Ripping
« Reply #12 on: August 20, 2020, 08:53:22 pm »
Hmmm!
Worth a try.
[email protected] ~ $ sudo apt install asunder
Sorry, try again.
E: Unable to locate package asunder
My computers:
Acer Chromebook
Offline Melissa
  • Vintage nerd
  • Gender: Female
Re: CD Ripping
« Reply #13 on: August 20, 2020, 08:54:00 pm »
No such luck Keith!
My computers:
Acer Chromebook
Re: CD Ripping
« Reply #14 on: August 20, 2020, 08:57:27 pm »
OK.  I'll have a think.
