Author Topic: CD Ripping  (Read 3471 times)
Re: CD Ripping
« Reply #15 on: August 20, 2020, 09:03:11 pm »
Melisssa,
Try
sudo apt install clementine
and have a look at https://www.youtube.com/watch?v=nPkEHiSsVDc
Offline wishbone
Re: CD Ripping
« Reply #16 on: August 20, 2020, 09:45:44 pm »
Have you tried xfburn?
Re: CD Ripping
Offline Melissa
  • Vintage nerd
  • Gender: Female
Re: CD Ripping
« Reply #17 on: August 20, 2020, 10:31:35 pm »
OK.  I'll have a think.
Thank you. Very odd that they are not there in the Peppermint distro.
My computers:
Acer Chromebook
Asus notebook x102B, running on Peppermint 9.
Offline Melissa
  • Vintage nerd
  • Gender: Female
Re: CD Ripping
« Reply #18 on: August 20, 2020, 10:33:17 pm »
It's not in the package manager nor the software manager either. I looked online for names of all the Linux CD ripping software and none are in my package managers! This is very odd.
My computers:
Acer Chromebook
Re: CD Ripping
« Reply #19 on: August 21, 2020, 11:22:50 am »
Melissa,
The link I gave earlier is a Youtube video entitled "Ripping CDs In Peppermint with Clementine" so is definitely worth a look.
Here it is again: https://www.youtube.com/watch?v=nPkEHiSsVDc
Re: CD Ripping
Re: CD Ripping
« Reply #20 on: August 21, 2020, 07:05:10 pm »
.....alternatively:  you might try downloading Brasero from the internet and installing it yourself.
If you search for "brasero linux download" you will find lots of places to download it from,  e.g. https://download.cnet.com/Brasero-for-Linux/3000-2646_4-75207025.html.
Since Peppermint is Ubuntu-based I am fairly confident that it will work OK.
Let me know what you think.
Offline Melissa
  • Vintage nerd
  • Gender: Female
Re: CD Ripping
« Reply #21 on: August 22, 2020, 06:57:55 pm »
Melissa,
Thank you. I'll look at it on Sunday.
My computers:
Acer Chromebook
Offline Melissa
  • Vintage nerd
  • Gender: Female
Re: CD Ripping
« Reply #22 on: August 22, 2020, 06:59:40 pm »
Melisssa,
Try
Did not work either!
 $ sudo apt install clementine
[sudo] password for matildaw:
Reading package lists... Done
Building dependency tree
No apt package "clementine", but there is a snap with that name.
Try "snap install clementine"
E: Unable to locate package clementine
[email protected] ~ $
My computers:
Acer Chromebook
Offline Melissa
  • Vintage nerd
  • Gender: Female
Re: CD Ripping
« Reply #23 on: August 22, 2020, 07:01:10 pm »
Well I know how to download it- save the folder on my desktop, but after that I don't know how to install it. Mark used to tell me what to do next on such things.
My computers:
Acer Chromebook
Re: CD Ripping
Re: CD Ripping
« Reply #24 on: August 22, 2020, 07:08:27 pm »
I think I just double-clicked on the file and it installed - try it.
Offline wishbone
Re: CD Ripping
« Reply #25 on: August 22, 2020, 10:40:36 pm »
Try "sudo dpkg -l brasero" to confirm it`s not there.
As Keith said try "sudo apt-get update" to update, then "sudo apt-get install brasero", then try " sudo dpkg -l brasero" again to confirm it is there, or not.
Sorry it`s a repetition, belt & braces aproach.
Offline Davdi_J_D
Re: CD Ripping
« Reply #26 on: August 23, 2020, 07:55:17 pm »
If, after  Keith's and Wishbone's suggestions, you still are missing Brasero, you can download it here: https://pkgs.org/download/brasero, for your Peppermint 9, scroll down to Ubuntu 18.04 and download that version. It should be a .deb file. Peppermint should install it using gdebi. Don't forget you'll need to use your password to authorise it.
Re: CD Ripping
« Reply #27 on: August 23, 2020, 11:09:12 pm »
That's a very useful site, David.  Solved a different problem for me.  Many thanks.
Re: CD Ripping
« Reply #28 on: September 08, 2020, 11:10:13 am »
Hi Melissa.
Did you succeed in downloading Brasero from either of the sites suggested?
If you have solved your problem (in any way) please let us know and mark your post as Solved.
As an aside;
1. The latest version of Audacity (2.2.1) will save MP3 files as WAV files that you can burn to a CD and play on your retro radio.
2.  Xubuntu has many CD/DVD burners available for installation (along with many other useful applications) and will work well on your netbook, so you might consider installing it.
Offline Melissa
  • Vintage nerd
  • Gender: Female
Re: CD Ripping
« Reply #29 on: September 22, 2020, 10:50:46 am »
Sorry guys, I have a new Chromebook ( refurbished one off Ebay so new to me) which is my main laptop now ( it has an SSD drive so is very fast!) so not been using my Linux netbook that much lately ( use it mostly for scanning pix). I'll power it up tomorrow and try and see if I can get Brasero on it using your instructions.
My computers:
Acer Chromebook
