Author Topic: CD Ripping  (Read 4227 times)
Offline mikep
  • Sr. Member
  • Me again!
Re: CD Ripping
« Reply #30 on: November 01, 2020, 12:50:00 am »
Just a thought, Melissa,
Can't you use the data stick and chromebook to burn CDs?
I'm not familiar with the chromebook so I may be completely wrong...
« Last Edit: November 01, 2020, 01:11:42 am by mikep »
Offline Melissa
  • Vintage nerd
  • Gender: Female
Re: CD Ripping
« Reply #31 on: November 01, 2020, 09:03:56 pm »
No because it has no CD drive, nor can you use external CD/DVD drives on it. I forgot to look again at the netbook. My friend Dave was doing some CDs for me on his Windows computer and using media player but last time I saw him he was having trouble with it ( probably needed an update ).
I've since bought a GPO Chesterton record player that looks a bit like an old radio and the usb stick works on that so I've been using it to play the mp3s on.
You can record off devices on it  but I don't think it does mp3s to CDS- not figured that out yet. It can play vinyl records, CDs, cassettes and mp3s off a data stick.
My computers:
Acer Chromebook
Asus notebook x102B, running on Peppermint 9.
Re: CD Ripping
Offline emegra
Re: CD Ripping
« Reply #32 on: January 06, 2021, 09:02:55 pm »
Hi Melissa
You can try sound-juicer
sudo sudo apt-get update
sudo apt-get install sound-juicer
Offline Tramlink
  • Is the mist clearing
Re: CD Ripping
« Reply #33 on: January 07, 2021, 09:25:23 am »
I use a program called K3b for all CDs and DVDs it has worked for me on different versions of mint over the years.
If not in your package or software manager - http://www.k3b.org
