Hi,
There are a number of ways to do this, one easy way is to install
auditd, on a debian system like this;
Once installed this will start tracking issues and you can use the
aureport command to produce reports, for example;
# aureport -l --failed
Login Report
# date time auid host term exe success event
1. 10/05/2020 11:43:51 gareth 192.168.250.2 sshd /usr/sbin/sshd no 39
2. 10/05/2020 11:44:01 (unknown user) 192.168.250.2 sshd /usr/sbin/sshd no 55
3. 10/05/2020 11:44:01 (invalid user) 192.168.250.2 sshd /usr/sbin/sshd no 56
# aureport -l --success
Login Report
1. 10/05/2020 11:43:56 0 192.168.250.2 /dev/pts/0 /usr/sbin/sshd yes 50
2. 10/05/2020 11:44:04 0 192.168.250.2 /dev/pts/0 /usr/sbin/sshd yes 67
3. 10/05/2020 11:44:55 0 192.168.250.2 /dev/pts/0 /usr/sbin/sshd yes 81
# aureport -l --success --summary -i
Success Login Summary Report
total auid
3 root
# aureport -l --summary -i --failed
Failed Login Summary Report
total auid
1 gareth
1 (unknown user)
1 (invalid user)
Is this the sort of thing you were looking for?
