HiUsing a Chromebook, and just installed Linux Beta, then installed Linux Wine, all ok.Using Wine, installed Microsoft Money ver. 4 , went through Install ok. Icons have appeared in the Linux Apps folder on Launcher for Microsoft Money. If I go into the Linux files and in Wine folder dlnet deltanet launch Money, it runs fine. So the program as installed ok, good But if I click on the icon in the Linux Apps folder on the Launcher or Chromebook, it gives error File not found.I assume that the Path is incorrect.But I cannot find, how to modify the properties of this icon. A lack of understanding how or where they are picked up from the install in Linux / Wine and then put into the Chromebook Launcher.
Quote from: tony_a on October 31, 2020, 05:05:14 pmHiUsing a Chromebook, and just installed Linux Beta, then installed Linux Wine, all ok.Using Wine, installed Microsoft Money ver. 4 , went through Install ok.Icons have appeared in the Linux Apps folder on Launcher for Microsoft Money.If I go into the Linux files and in Wine folder launch Money, it runs fine.So the program as installed ok, goodBut if I click on the icon in the Linux Apps folder on the Launcher or Chromebook, it gives errorFile not found.I assume that the Path is incorrect.But I cannot find, how to modify the properties of this icon.A lack of understanding how or where they are picked up from the install in Linux / Wine and then put into the Chromebook Launcher.is this issue solved? if yes, can you please update it here. I'm having the same issue
Mmm, I'm led to believe the M$ Money is quite an old product and not something even M$ support any more (?) and as a result getting it to work on WINE can be problematic. If this is true, then it might be worth looking at an alternative, either a native Linux app, or even an online application. Have you had a look at; https://kmymoney.org/
