Author Topic: Scangearmp2 SOLVED.  (Read 2777 times)
Offline 19goalie50nxQ
Re: Scangearmp2
« Reply #30 on: December 28, 2020, 01:09:14 pm »
Keith before I do anything silly, can you clarify what you mean by this :-" I suggest to use the text editor supplied by Mint (don't use LibreOffice!)".  I copied your Code command gedit .profile and pasted into Terminal then pressed Enter I hope this was okay.
Also again to clarify :- "When asking your editor to open .profile, don't forget to use Ctrl+h so you can see hidden files"  I'm not sure where use" .profile" is it in Terminal command after :- sudo apt install gedit.  Sorry to labour on this I don't want to mess things up can you let me have the command to proceed correctly.
Goalie.
Re: Scangearmp2
« Reply #31 on: December 28, 2020, 01:18:34 pm »
When you pasted the command gedit .profile into your terminal it produced an error because the text editor gedit is not installed on your computer.
You have two options:
1. install gedit as suggested or
2. look in your Mint menus to find your text editor - I think it might be called pluma
For simplicity I suggest using the one already installed.  After starting that editor, open .profile not forgetting to display "hidden files" so that you can see it!.
Re: Scangearmp2
Re: Scangearmp2
« Reply #32 on: December 28, 2020, 01:47:49 pm »
Keith I'm learning more each time you contact me, to be honest I've never used a text editor so don't know how to use it. However I've checked what is installed and it is Nano also in the Software Manager I notice there is Gedit so I can install it if this will make things easier.
Also I apologise for taking longer to reply sometimes its just that being "confined to barracks" so to speak, I have to help my wife with chores when she asks me. Plus she can't understand why I seem to be on the computer all the time mind, it doesn't matter that she's on WhatsApp all the time.lol
Goalie
Re: Scangearmp2
« Reply #33 on: December 28, 2020, 01:55:37 pm »
No problem Goalie.  You're doing fine.
As I am more familiar with gedit, let's install that.  Enter the following
You will be asked for your password.  As you type it nothing will appear on the screen.  This is normal, so you will have to be careful in your typing.  Don't forget to press "Enter"!
As the screen fills up it may ask you if you are happy to proceed - type y (and press Enter if nothing happens).
When your user-prompt reappears, gedit is installed.  Let me know when that's done and we'll move on.
Re: Scangearmp2
« Reply #34 on: December 28, 2020, 02:25:02 pm »
Gedit fully installed.
Re: Scangearmp2
Re: Scangearmp2
« Reply #35 on: December 28, 2020, 02:31:30 pm »
Jolly good!
I've a thought.  Best check if you actually have a file called .profile.  Enter the following:
ls .profile
If the result looks like
[email protected]:~$ ls .profile
.profile
Then we are in business.
Re: Scangearmp2
« Reply #36 on: December 28, 2020, 02:37:53 pm »
No joy see copy off Terminal :- [email protected]:~$ ls .profile
.profile
Could I have done something wrong again?
Re: Scangearmp2
« Reply #37 on: December 28, 2020, 02:44:51 pm »
Perfect!!  The file .profile is listed.
Now enter the following:
gedit .profile
This will start the gedit text editor and fill it with the .profile file.
Go to the bottom of the page and you will see something like:
# set PATH so it includes user's private bin directories
PATH="$PATH:$HOME/.bin:$HOME/.local/bin
Whatever it says, please copy the whole of the last two lines and post them here.
Re: Scangearmp2
« Reply #38 on: December 28, 2020, 02:47:49 pm »
Copy of last two lines :-
# set PATH so it includes user's private bin if it exists
if [ -d "$HOME/bin" ] ; then
    PATH="$HOME/bin:$PATH"
fi
if [ -d "$HOME/.local/bin" ] ; then
    PATH="$HOME/.local/bin:$PATH"
fi
Re: Scangearmp2
Re: Scangearmp2
« Reply #39 on: December 28, 2020, 03:02:37 pm »
That's good: it means that no other additions have been made and we can add our .scangear directory to the PATH.
Copy the following lines and add them to the bottom of the file:
# set PATH so it includes user's .scangear directory if it exists
if [ -d "$HOME/.scangear" ] ; then
    PATH="$HOME/.scangear/scangearmp2-3.60-1-deb:$PATH"
fi
Then copy the last 12 lines or so and paste them here.  Don't close gedit yet!!
Re: Scangearmp2
« Reply #40 on: December 28, 2020, 03:08:28 pm »
Hope these are correct:-
# if running bash
if [ -n "$BASH_VERSION" ]; then
    # include .bashrc if it exists
    if [ -f "$HOME/.bashrc" ]; then
   . "$HOME/.bashrc"
    fi
fi
fi
fi
fi
Re: Scangearmp2
« Reply #41 on: December 28, 2020, 03:13:45 pm »
You omitted the comment line but it's not important.
Yes; that's fine.  Now save the edited file and close gedit.
Then:
1. Reboot your computer
2. In a terminal, enter:
echo $PATH
and copy the output here.
Re: Scangearmp2
« Reply #42 on: December 28, 2020, 03:20:48 pm »
Copy of Terminal after reboot:-
[email protected]:~$ echo $PATH
/home/kevin/.scangear/scangearmp2-3.60-1-deb:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
Re: Scangearmp2
« Reply #43 on: December 28, 2020, 03:24:59 pm »
Good.
Now in your terminal enter:
install.sh
You will need to enter your password when asked.
Paste the output here.
Re: Scangearmp2
« Reply #44 on: December 28, 2020, 03:28:23 pm »
Doesn't look good?
ScanGear MP
Version 3.60
Copyright CANON INC. 2007-2018
Command executed = sudo dpkg -iG /home/kevin/.scangear/scangearmp2-3.60-1-deb/packages/scangearmp2_3.60-1_amd64.deb
(Reading database ... 376255 files and directories currently installed.)
Preparing to unpack .../scangearmp2_3.60-1_amd64.deb ...
Unpacking scangearmp2 (3.60-1) ...
dpkg: error processing archive /home/kevin/.scangear/scangearmp2-3.60-1-deb/packages/scangearmp2_3.60-1_amd64.deb (--install):
 trying to overwrite '/usr/lib/libcncpmslld2.so.3.0.0', which is also in package libcanon-proprio-bin 0.2+4.10-1804ubuntu1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Command executed = sudo dpkg -P scangearmp2
dpkg: warning: ignoring request to remove scangearmp2 which isn't installed
