Author Topic: Scangearmp2 SOLVED.  (Read 1911 times)
Offline 19goalie50nxQ
Re: Scangearmp2
« Reply #60 on: December 28, 2020, 08:05:38 pm »
Copy of your last command :-
[email protected]:~$ sudo mv /usr/lib/libcncpmslld2.so.3.0.0.bak   /usr/lib/libcncpmslld2.so.3.0.0
[sudo] password for kevin:
Keith I appreciate greatly what you are doing for me on this matter, I suggest we "put it to bed" for tonight and tackle it with a fresh mind tomorrow.
All for now.
Goalie
Re: Scangearmp2
« Reply #61 on: December 28, 2020, 08:07:12 pm »
Good idea!
Re: Scangearmp2
Re: Scangearmp2
« Reply #62 on: December 29, 2020, 08:53:35 pm »
Hi Keith.
I've removed and reinstalled the printer driver for my Canon Tr8550 printer, then tried to install the scangear without success. I 'surfed' the Ubuntu Forum and came across the link :- https://askubuntu.com/questions/1237107/scangear-driver-for-canon-ts3150-at-ubuntu-20-04-not-working
I know that this probably isn't the same for Linux Mint thought it might give you a lead to possibly find a solution to the Scangear problem.
Don't go out of your way to look at this until after New Year holiday, I'm able to use the printing features of the printers so I'm okay with them at the moment.
Best wishes for a Happy New Year.
Goalie
Re: Scangearmp2
« Reply #63 on: December 29, 2020, 09:20:45 pm »
Hi Goalie.
From the URL you mention it seems that many people are having the same problem with their canon printer/scanners - which is not encouraging.
Several approaches are mentioned so it might be useful to try them all.  If none of those work, I have another suggestion.
In your terminal, enter:
sudo apt remove ippusbxd
then reboot.
Then:
scanimage -L
and post the output here.  (It might take a minute or so to find your scanner)
« Last Edit: December 29, 2020, 09:22:53 pm by Keith »
Re: Scangearmp2
« Reply #64 on: December 29, 2020, 09:35:55 pm »
Hi Keith.
Copy of commands in Teminal : _
[email protected]:~$ sudo apt remove ippusbxd
Reading package lists... Done
Building dependency tree
Package 'ippusbxd' is not installed, so not removed
[email protected]:~$ scanimage -L
Re: Scangearmp2
Re: Scangearmp2
« Reply #65 on: December 29, 2020, 09:41:19 pm »
Now try:
sudo usermod -a -G dialout $USER
and reboot
Re: Scangearmp2
« Reply #66 on: December 29, 2020, 09:47:54 pm »
Sorry no joy here.
No scanner detected after reboot the printer is switched on.
Re: Scangearmp2
« Reply #67 on: December 29, 2020, 09:51:01 pm »
Try
export SANE_DEBUG_PIXMA=11 && scanimage > /dev/null
sudo scanimage -L
(and wait a  bit for a result)
Re: Scangearmp2
« Reply #68 on: December 29, 2020, 09:53:43 pm »
Sorry Keith thought we had done it this time.
[email protected]:~$ export SANE_DEBUG_PIXMA=11 && scanimage > /dev/null
[sanei_debug] Setting debug level of pixma to 11.
[pixma] pixma is compiled with pthread support.
[pixma] pixma version 0.17.37
[pixma] pixma_find_scanners() found 0 devices
scanimage: no SANE devices found
[email protected]:~$ sudo scanimage -L
Re: Scangearmp2
Re: Scangearmp2
« Reply #69 on: December 29, 2020, 09:56:58 pm »
Keith I have installed both Simple Scan & Xsane so should these be picked up by your searches?
Goalie
Re: Scangearmp2
« Reply #70 on: December 29, 2020, 09:59:47 pm »
As you were posting I was writing to suggest installing Xsane.  Have you tried it?
Re: Scangearmp2
« Reply #71 on: December 29, 2020, 10:01:48 pm »
I've tried both Xsane and Simple Scan and both say no scanner detected.
Doi you want to leave this until after New Year?
Re: Scangearmp2
« Reply #72 on: December 29, 2020, 10:16:06 pm »
Another user elsewhere had the same problem with an HP printer on Mint.  His final solution (https://www.linuxquestions.org/questions/linux-software-2/xsane-not-working-in-mint-20-a-4175680585/#post6158608) was to just re-install Mint - which worked.
I must add that recent Ubuntu updates have been messing my installation of Ubuntu 18.04 although my HP printer/scanner is still working, so you are not alone.
I can't think of any other things to try, and suggest that you re-install Mint.
I'm very sorry that I've been unable to solve your difficulties.
Re: Scangearmp2
« Reply #73 on: December 29, 2020, 10:23:51 pm »
Keith thanks for your perseverance with this problem and I will reboot Mint when the next upgrade is out in January.
Best wishes and I'll let you know how I get on with the reboot.
Goalie
Re: Scangearmp2
« Reply #74 on: December 29, 2020, 10:26:25 pm »
I suspect that a simple upgrade will not suffice and a complete re-installation will be necessary - but good luck anyway.
Best wishes to you & yours for the new year.
