Author Topic: VPN for linux [Solved]  (Read 667 times)
Offline mikekane
« on: December 30, 2020, 12:49:59 pm »
Is it worth having a linux VPN? As I was reading this page
https://www.purevpn.com/download/linux-vpn
and thought that would it be necessary or just an extra protection.
« Last Edit: January 02, 2021, 07:22:46 am by mikekane »
Re: VPN for linux
« Reply #1 on: December 30, 2020, 01:12:42 pm »
Hello Mikekane - and welcome to the Forum.
Virtual Private Networks aren't necessary but can be useful.  For example; I object to the way Google tracks one all over the web and accumulates information about users gathered from all Google's applications that are being used increasingly by your everyday, high-street company.  So if I need to use Google Maps (which I have to say is very good) I use a VPN to hide my location and IP address.
But it's not all plain-sailing.  Free VPNs are free for a reason, just as Google & Facebook are, so one might think that a paid-for VPN service would be better but this is not always the case.  This link https://us.norton.com/internetsecurity-privacy-safe-vpn.html from Norton (of anti-virus fame) explains VPNs and what to look out for.
There are trustworthy VPN services available for free: I use the free version of protonvpn - look here for pricing plans: https://protonvpn.com/about.  The free version is supported by the income they receive from those who pay.  Proton mail also has a free mail service that is ultra secure - do look at https://protonmail.com/.  All communication between you and their servers is encrypted and if you lose your password, they can't help you as even they can't access your files!
Overall; I would say that the use of a VPN depends on how keen you are to avoid even your ISP snooping on you, and if you decide to use one I thoroughly recommend Protonvpn (and Protonmail).
Re: VPN for linux
Offline mikekane
Re: VPN for linux
« Reply #2 on: December 31, 2020, 09:06:59 am »
Thanks a lot for detailed response
But I have doubt on one point that if you use a VPN for google maps then you can change your IP address but how are you going to change your location? as google will easily pinpoint it with geo location services.
Re: VPN for linux
« Reply #3 on: December 31, 2020, 11:02:39 am »
Google pinpoints the location of the VPN server - your location is entirely hidden behind the VPN.  This website gives a very good overview of how VPNs work: https://thebestvpn.com/what-is-vpn-beginners-guide/.
Here are some others, and a web search will reveal many more:
https://www.expressvpn.com/what-is-vpn/vpn-for-dummies
https://www.digitalconnectmag.com/how-does-vpn-work-privacy-basics-for-beginners/
https://www.wizcase.com/blog/what-is-a-vpn-a-beginners-guide/
By the way:  To avoid being tracked by Google I recommend that you don't use the Google search engine (although they have other ways!) but use DuckDuckGo instead.  This is a very secure search provider that doesn't track you or provide your details to anyone else.  I suggest that you take a look at https://duckduckgo.com/spread.  DDG has one of the shortest (and best) privacy statements I've encountered (https://duckduckgo.com/privacy).
Other secure search engines are https://www.oscobo.com/ (British, I think) and https://swisscows.ch/
« Last Edit: December 31, 2020, 11:05:56 am by Keith »
Offline mikekane
Re: VPN for linux
« Reply #4 on: January 01, 2021, 11:47:48 am »
Got it thanks again for the  detailed response
Re: VPN for linux
Re: VPN for linux
« Reply #5 on: January 01, 2021, 11:49:44 am »
Hello Mike,
Jolly good.
Please edit the title of your first post to add "[Solved]".
Thank you.
Offline mikekane
Re: VPN for linux [Solved]
« Reply #6 on: January 02, 2021, 07:23:05 am »
Done
