Author Topic: Uising Unbutu to back up macbook hard drive  (Read 146 times)
Offline infinitexpanse
« on: December 30, 2020, 05:29:24 pm »
Hi I was hoping someone would be able to help me. I have a macbook pro ssd hard drive in a damaged macbook pro I want to remove and back up. The only computer I have access to do this with is one running Ubuntu 20.04 LTS 64bit. Is it possible If I connect the removed ssd via usb to the computer will I then be able to access and backup the contents of the the ssd onto another hard drive using unbutu? If so what application should I use?
Help will be really appreciated. Many thanks :)
Re: Uising Unbutu to back up macbook hard drive
« Reply #1 on: December 30, 2020, 09:11:07 pm »
Hello  - and welcome to the Forum.
You will need to put the SSD into a suitable enclosure that will plug into a USB port.  Ubuntu will then treat it just like another directory from which you can back up your files.
There are fancy backup applications - indeed Ubuntu comes with a backup facility that you can find out about here: https://linuxconfig.org/ubuntu-20-04-system-backup-and-restore.  However, it might be easier simply to use commands in a terminal.  Let us know if you would like to do this.
Offline emegra
« Reply #2 on: January 06, 2021, 09:38:27 pm »
Unless I'm mistaken macos uses hfs filesystem which I don't think ubuntu can read/write natively
if so there is some info here to help you mount a hfs drive in Ubuntu
https://itectec.com/ubuntu/ubuntu-how-to-read-and-write-hfs-journaled-external-hdd-in-ubuntu-without-access-to-os-x
Good luck
« Last Edit: January 07, 2021, 05:21:28 am by emegra »
