Author Topic: Operating system not found - DVD Issue  (Read 403 times)
Offline emegra
Re: Operating system not found - DVD Issue
« Reply #15 on: January 09, 2021, 08:34:42 pm »
The DVD drive only shows in the boot order
Well if it shows in the boot order then the system must be seeing it
can you make it first boot device then try booting a live DVD again ?
Offline MattC
« Reply #16 on: January 09, 2021, 08:50:11 pm »
Not really.  At present, I have removed the DVD drive in order to allow the HDD to boot up.  The DVD drive is still showing in the boot order.  I think it's a standard setting.
« Reply #17 on: January 09, 2021, 08:53:53 pm »
I believe you are right, Matt:  depending on the age of a computer, the BIOS may show boot orders for floppy-disc, USB-stick, CD/DVD and HDD even if floppy/USB/DVD drives don't exist.
Offline emegra
« Reply #18 on: January 09, 2021, 08:54:25 pm »
yeah you're probably right
So am I right in thinking that when you reconnect the DVD drive it just slots inside a bay, you don't have to physically connect any cables ?
Offline MattC
« Reply #19 on: January 09, 2021, 09:22:36 pm »
emegra, that's correct.
Offline emegra
« Reply #20 on: January 10, 2021, 06:24:15 am »
According to this https://www.laptopsdirect.co.uk/acer_travelmate_4062lci_lx.tak05.293/version.asp the 4062lci doesn't have a DVD it comes with a CD Rewriter, it's sister model (4062lmi) has a DVD.
Can you confirm for me the drive is DVD and not CD
also according to the same page you should have 3x usb2 ports, but you said there's no usb bios support, so can you confirm if you do have usb ports and what you mean by no bios support ?
also if connecting the drive stops the HDD booting can you confirm if the drive has a disc in the tray, if so have you tried connecting with the tray empty ?
Offline MattC
« Reply #21 on: January 10, 2021, 08:40:20 am »
The sticker on the back states that the unit is a LCi.  The drive is a DVD reader/CD rewriter.
There are three USB ports, but the BIOS does not allow the USB in the boot order - either through setup or F12.  According to the BIOS it is possible to boot from a FDD, which it doesn't have, and a network.  Plugging in a bootable USB (which I know works) into the USB port and starting the computer and pressing F12 doesn't bring up a USB bootable, either.
Both.  With and without a disc in place.
Offline emegra
« Reply #22 on: January 10, 2021, 09:46:33 am »
ok well if the HDD isn't booting only when the DVD drive is connected, then that would suggest the DVD drive is faulty or worse so if you have another DVD drive you can connect it would be worth the effort to confirm that, it would be helpful to know for certain that the drive is ok.
alternatively you can try completely powering down the laptop, remove the battery for 30 secs or so reconnect the DVD drive and try booting up ( I know that sounds crazy but stranger things have happened)
otherwise I don't know what else to suggest at this point.
RE the USB
it's possible that it's capable of USB boot but turned off by default and there may be some setting hidden away in the BIOS you can change to allow it, I had this issue a long time ago where I had to change something in the BIOS to allow USB boot but it's so long ago I can't remember and I've trawled the internet and can't find anything regarding your machine
Offline MattC
« Reply #23 on: January 10, 2021, 11:06:50 am »
I have nothing else I can try the drive in, but I have two other drives of the same type that I'm pretty certain work.  Neither of them alleviate the problem.
I'll try the battery removal, but I'm sure I've done this before.
I can't find anything to turn the USB on or off.  The BIOS is so simple, I'm sure I'd find it somewhere.  If I can, I'll try to take a pic of the screens.
Offline emegra
« Reply #24 on: January 10, 2021, 11:18:59 am »
Do both these drives kill the HDD in the same way ?
Can you tell me the current boot order in the BIOS ?
Offline MattC
« Reply #25 on: January 10, 2021, 01:19:49 pm »
Just tried putting the drive back in and booting up.  Guess what?  The HDD booted.  It did seem to try to access the DVD drive first, though, which has a film DVD in.  The boot order is HDD, DVD/CD, FDD.  Going back to the question that was asked several posts ago (ls /media/…) as I can now access the OS with the DVD drive in:
from matt account:
/cdrom : no result
/guest : permission denied
/matt : no result
I've attached the screen shots of the BIOS.  Note: the info is basic.
Offline emegra
« Reply #26 on: January 10, 2021, 02:34:31 pm »
When you ran
ls /media/matt
did you have a DVD with files written on it in the tray ?
if not can you please do that and post the output ?
Offline MattC
« Reply #27 on: January 10, 2021, 03:22:43 pm »
After, again, problems getting the HDD to load with the DVD drive installed, the results of a data disc  show the same as before: no results bar the guest's.
Offline emegra
« Reply #28 on: January 10, 2021, 03:42:14 pm »
there's still a possibility the DVD drive is faulty but if you've tried 2 others with the same results is kinda unlikely, it seems to me the DVD isn't being activated at start up which points to a bios/motherboard  issue, but I'm no expert and I'm rapidly running out of ideas, I've been trawling the internet looking for clues, the closest I could find was this guy who had a very similar problem and found a solution here
https://forums.tomshardware.com/threads/boot-options-replaced-with-fdd.2113695/
If all else fails the only way I can suggest to get a new operating system on the machine is to remove the drive and install it into another machine, install the OS then put it back but that might be more hassle than it's worth
Just a thought have you tried to see if the drive will read a CD ?
« Last Edit: January 10, 2021, 03:44:34 pm by emegra »
Offline MattC
« Reply #29 on: January 10, 2021, 05:06:29 pm »
OK!  Now here's the thing.   :-[
It's fixed!  Let me explain.
Right at the start I tried another two DVD drives.  Neither of them worked.  Or at least, so I thought/remembered.  Taking another laptop apart and pulling out a compatible drive, I have just tried that one.  It works fine - the HDD boots up and the OS reads the drive.  I retried all the other drives and found that the original one and one of the other spares caused the problem, but the third one of the original ones I tried also works fine.  (Not sure why I thought it didn't work originally - maybe I hadn't quite put it in correctly.)  This third one I have properly installed and tried several times.  It still works fine.  Conclusion: the original one and one of the spares are faulty - just like you stated.   ::)
There is one unanswered question, though.  Why was the problem drive causing the BIOS to ignore the HDD, despite it being first in line?
Whether this question is answered or not, please let me 'voice' my appreciation for all the help and patience offered.
Matt
