Author Topic: Operating system not found - DVD Issue  (Read 401 times)
Offline emegra
Re: Operating system not found - DVD Issue
« Reply #30 on: January 10, 2021, 05:21:17 pm »
Great news
Glad you got it working Matt I applaud your perseverance :)
Why was the problem drive causing the BIOS to ignore the HDD, despite it being first in line?
Wish I could answer that, but my guess is the DVD & HDD are connected to the same IDE channel in a Master/Slave configuration and the faulty DVD was probably taking out the whole channel
Does that make sense ? :)
Anyway all's well that ends well
Offline MattC
« Reply #31 on: January 10, 2021, 05:25:02 pm »
When you put it like that, it makes perfect sense.
Thanks again.
Matt
