Author Topic: Liux Mint Photoprint. SOLVED  (Read 440 times)
Offline 19goalie50nxQ
« on: January 16, 2021, 03:39:37 pm »
Before I upgrade from Linux Mint 19.3 to Linux Mint 20.1 is Photoprint or equivalent available in Mint 20.1.
Regards
19goalie50nxQ
« Last Edit: January 18, 2021, 12:36:09 pm by 19goalie50nxQ »
Offline emegra
Re: Liux Mint Photoprint.
« Reply #1 on: January 16, 2021, 05:35:34 pm »
Hi
I'm running xubuntu 20.04 and it's not in the repos so it looks like the short answer is no
I used to use Photoprint myself and loved it but I gave up on it through lack of development, it seem the last update it had was around 2010 (0.4.2)
see here
http://blackfiveimaging.co.uk/index.php?article=02Software%2F01PhotoPrint
which is a shame because it was a superb application.
The last pre-package binary file I can find is for 18.04 but there's dependency issues and it wont install on my system.
you'll find it here
http://archive.ubuntu.com/ubuntu/pool/universe/p/photoprint/photoprint_0.4.2~pre2-2.5_amd64.deb
Source files here
If it's any help I use showfoto which can do the same job and a lot more but it's a KDE application
Good luck
Offline DavidMcCann
« Reply #2 on: January 16, 2021, 05:46:49 pm »
It doesn't seem to be. It's reported as having problems on modern systems, which is not surprising since the last version dates from 2010.
A photo-editing tool might do the same job — have a look here https://linuxappfinder.com/graphics
« Reply #3 on: January 16, 2021, 07:25:34 pm »
Probably not very helpful;  but I installed photoprint_0.4.2-pre2 about a year ago on Ubuntu 18.04 and it's working well.
I can't remember where I installed it from, but the fact that it's working gives cause for hope, although perhaps it's only good on the full Ubuntu installation.
« Reply #4 on: January 18, 2021, 10:09:03 am »
Hello Graeme, David & Keith.
Sorry I've not replied before now and thanks for your replies and note that Photoprint isn’t available in Mint 20.1 that’s a pity Photoprint is simple to use. I’ll have a look at your individual suggestions for other applications before installing Mint 20.1. and consider this item is solved.
Goalie
Re: Liux Mint Photoprint. SOLVED
« Reply #5 on: January 18, 2021, 10:11:28 am »
This item has been solved.
Regards.
Goalie
« Reply #6 on: January 18, 2021, 10:28:04 am »
Thanks, Goalie - and good luck with progress.
By the way:  if you add [SOLVED] to the title of your first post in this topic, it will appear in the title on the Forum page so everyone can see it.
« Reply #7 on: January 18, 2021, 12:32:35 pm »
Keith.
Thanks for your reminder as to how to confirm problem is  'Solved'. I'm still learning how to use Linux Mint and Forum. I have another problem I will send as a new topic later.
Regards
Goalie
« Reply #8 on: January 18, 2021, 01:27:13 pm »
Many thanks, Goalie - we'll see you later.
