Author Topic: Getting to boot Menu on HP Pavilion Laptop(Solved)  (Read 1181 times)
Offline Degsy
  • Sr. Member
« on: January 27, 2021, 08:01:47 pm »
Hi,
I am trying to assist a friend who is sick of Windows 10, he has a pavilion netbbok laptop, he has downloaded peppermint 10 to a USB but cannot get into the boot menu to try the peppermint with a view to replacing Windows.
Can someone please give a step by step guide to get into the boot menu, it seems much more complicated than on my Dell laptop.
your help is much appreciated,
Regards,
Degsy
« Last Edit: February 06, 2021, 11:15:54 am by Degsy »
Offline wishbone
Re: Getting to boot Menu on HP Pavilion Laptop
« Reply #1 on: January 27, 2021, 08:33:23 pm »
Does pressing F10 or ESC work when booting at the blank screen?
Offline Degsy
  • Sr. Member
« Reply #2 on: January 28, 2021, 09:43:29 am »
Hi,
Thanks for the response, he has tried the various "simple" options, eg, F10, Esc etc but apparently this doesn't get him to the boot order screen.
My first advice to him was on those lines, I just tap F12 on my Dell and up pops the boot screen.
Is this something yo do with Windpws and uefi? It us so long since I had windows and it as certainly pre uefi.
Offline Rich J
  • Still a Linux Luvvie!
« Reply #3 on: January 28, 2021, 09:52:11 am »
Hi,
Regards,
Degsy
See here - https://support.hp.com/gb-en/document/c00364979
There *should* be instructions on the BIOS page, when it appears, on re-arranging the boot order.   As I recall, some older laptops might actually show 'USB' in the list but boot capability isn't activated.  If that's the case, change the boot order to DVD (or CD if it's that old) and try an installation disk instead.  ;)
Rich
Offline Degsy
  • Sr. Member
« Reply #4 on: January 28, 2021, 10:15:44 am »
Hi Rich,
Thanks for the reply, have passed on your advice to my friend and he will have a look at it and see if can sort it from there. Will come back and ask for further help if needed,
Many thanks
Degsy.
Offline Rich J
« Reply #5 on: January 29, 2021, 09:44:54 am »
Hi Rich,
Many thanks
Degsy.
No worries!  They may have to try all the sequences in turn, depending on the particular computer.  There seems to be as many BIOS versions as there are Linux distros.... ::)
Offline emegra
« Last Edit: June 23, 2021, 10:05:32 am by emegra »
Offline Zorba61
  • Full Member
« Reply #7 on: February 05, 2021, 08:40:24 am »
Some good answers here as well....https://www.quora.com/How-do-I-change-the-boot-device-order-on-a-Windows-10-HP-laptop-to-boot-from-a-USB.
I can confirm in the past I have had to hit the delete button on the keyboard to enter the boot menu...good luck.
Offline Degsy
  • Sr. Member
« Reply #8 on: February 06, 2021, 11:15:08 am »
Can I thank everyone who has posted responses to this query, I can say that my friend has found the correct sequence of keys to access the boot menu, it does appear to vary widely depending upon the actual model, also needed to go through secure boot option, but I think this is now sorted.
He is very appreciative of the help and has learned a lot.
Degsy
Re: Getting to boot Menu on HP Pavilion Laptop(Solved)
« Reply #9 on: February 06, 2021, 11:27:27 am »
Degsy,
Would you please ask your friend for the magic key combination and post it here for others?
Thanks,
keith
Offline Degsy
  • Sr. Member
« Reply #10 on: February 09, 2021, 07:02:08 pm »
Hi,
It appears that Tapping the Esc key followed by F9  did the trick.
Thanks again for the responses.
