Author Topic: unstable bridge with debian 10 server  (Read 170 times)
Offline Titicplusplus
« on: February 28, 2021, 02:13:59 pm »
Hello,
[Sorry for the clerical errors, I'm French]
I would like to use KVM on my debian server.
So I install the packages and i create the bridge (br0) :
 This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
source /etc/network/interfaces.d/*
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
allow-hotplug enp8s0 #my main connection
iface enp8s0 inet static
        address 192.168.1.68
        gateway 192.168.1.1
# This is an autoconfigured IPv6 interface
iface enp8s0 inet6 static
        address 2a01:cb06:d2:6c00:1ac0:4dff:fe60:bf74
        gateway 2a01:cb06:d2:6c00::/56
iface br0 inet static #my bridge
        address 192.168.1.69
        netmask 255.255.255.0
        bridge_ports enp8s0
        bridge_stp off
        bridge_waitport 0
        bridge_fd 0
When I run
ifup br0
, i don't have problem to start
Waiting for a max of 0 seconds for enp8s0 to become available.
Waiting for br0 to get ready (MAXWAIT is 2 seconds).
When I run
ifup br0
, I have no problem to start with.
But there are problems of stability.
Firstly, the server has 3 IP addresses: 192.168.1.68 (enp8s0), 192.168.1.69(br0) and 192.168.1.72?
Another thing, I installed "pi hole" (a dns) and when I wrote the 3 IP addresses, I arrived all the time on the main interface of "pi hole". I don't know if this is normal or not.
And sometimes the whole connection of my server stops for no apparent reason.
-> VNC and SSH are stopped and it is not possible to connect to the "pi hole".
So when I go to my server offline and try to restart the connection.
The only solution is to restart the server.
Do you have a solution to have a stable connection with a KVM bridge.
Thank you in advance.
For information: My server -> Debian GNU/Linux 10 server (buster) / ryzen 3 / 8go ram / connected with an internet cable to my orange livebox.
