Author Topic: Printers [SOLVED]  (Read 1359 times)
Offline Osmond
  • Full Member
Re: Printers
« Reply #15 on: April 08, 2021, 10:17:42 am »
Test page printed successfully. Set as default printer
Osmond
Re: Printers
« Reply #16 on: April 08, 2021, 01:57:19 pm »
So can you now print documents?
Re: Printers
Offline Osmond
  • Full Member
Re: Printers
« Reply #17 on: April 08, 2021, 04:24:13 pm »
Test print was successful. Selected default.
Re: Printers
« Reply #18 on: April 08, 2021, 04:26:03 pm »
Yes, you said earlier; but can you print a document of your own?
Offline Osmond
  • Full Member
Re: Printers
« Reply #19 on: April 08, 2021, 04:47:41 pm »
First try failed. In the "Print" window there are the following printers listed :
 DeskJet 2600, HP_DeskJet_2600_series_C8A2E5, HP-DeskJet-2600-series, hpdeskjet2600all-in-one. First try was with the third listed. I moved to the second listed and printing was successful on a personal document. Is it possible to delete all printer names except the one  that worked?
Osmond
Re: Printers
Re: Printers
« Reply #20 on: April 08, 2021, 04:52:21 pm »
That would be the best thing to do.
I am guessing that only the working one is listed in HPLIP, so you can delete the others through System Settings/Printers via the system menu.
Offline Osmond
  • Full Member
Re: Printers
« Reply #21 on: April 08, 2021, 06:39:02 pm »
Further testing shows that only one of the printer descriptions does not work, namely the one that most accurately describes it, DeskJet 2620. Curious. Printing now successful thanks to your kind help. Many thanks.
Osmond
Re: Printers
« Reply #22 on: April 08, 2021, 06:40:39 pm »
You are very welcome - glad it worked out for you.
Please edit the title of your first post as [SOLVED] - thanks.
