Author Topic: Linux Data  (Read 463 times)
Offline erics44
Linux Data
« on: May 12, 2021, 01:03:30 pm »
Hi
I'm brand new to Linux.
Is the linux data held in files? and can these be accessible from windows?
Thanks in advance
Re: Linux Data
« Reply #1 on: May 12, 2021, 02:03:33 pm »
Hello Erics44 - and welcome to the Forum.
What data are you referring to?  Certainly Linux, like any operating system, comprises a huge number of files and if you have both Linux and windows on the same computer (as a dual boot, perhaps) you will be able to access the windows files from Linux and probably the other way round, too.
We would need a bit more information about your setup before being able to comment further.
Re: Linux Data
Offline erics44
Re: Linux Data
« Reply #2 on: May 12, 2021, 02:23:26 pm »
Thanks for the reply
here is my very very limited understanding of linux
There isnt a database as such but the data is stored in files and each "table" has 1 data file and 1 index file.
So the linux system might be used to monitor company customers, so there might be 2 files, one with a list of customers and a second (index file) detailing the meta data of that file.
Thanks
Offline erics44
Re: Linux Data
« Reply #3 on: May 12, 2021, 02:26:08 pm »
maybe i completely misunderstand linux
Re: Linux Data
« Reply #4 on: May 12, 2021, 02:33:45 pm »
Linux is not a database at all - it is a computer operating system like the Windows or Apple operating systems.
If you are looking for a database, then a web-search for "Windows database software" or "Linux database software" will find many for you.
Whatever operating system you are using (I am guessing Windows) you will find that the built-in spreadsheet will have powerful database commands for extracting information.
If you choose to install Linux someone here can help you with the built-in "LibreOffice Calc" spreadsheets and database commands.
Hope that helps a bit.
Re: Linux Data
Offline erics44
Re: Linux Data
« Reply #5 on: May 12, 2021, 02:55:18 pm »
after further investigation :)
we have a server with a Linux environment and an application built in what might be Fortran
I know my investigation skills have not yet formed a really good picture of the situation
Re: Linux Data
« Reply #6 on: May 12, 2021, 03:11:43 pm »
It looks like you have a Linux-base server that provides Fortran scientific programming software.
Fortran has has advanced a lot since I was a lad and may well have database functionality but I suggest that you simply go to your computer manager and tell him/her what you want to do.
Alternatively, if you are provided with a Windows desktop environment, just use the built-in Microsoft Excel spreadsheet application and use its database functions.
Offline erics44
Re: Linux Data
« Reply #7 on: May 12, 2021, 03:24:32 pm »
the software was built in Fortran on a linux server by an external company
we know there are some files with data held in them and index files which determine the arrangement of each file
and thats just about all we know
we have little to no control over our data and really want to extract all of the data from this Fortran system over night and store it in an SQL Server database
If i could find the files and extract them into a windows environment i am sure i could write a bit of code that extracts the data
but maybe i am underestimating a lot of things, including how Linux and Windows can talk to each other
Re: Linux Data
« Reply #8 on: May 12, 2021, 04:05:18 pm »
Fortran is just an application for writing scientific software - like C++, BASIC, Python, etc.  It doesn't have data files in the sense that you mean.  If you have written Fortran code to save data files then those files will be accessible via the server operating system.
If you have no control over your data then you have a problem with your contract with the "external company".
Do you not have a computer operator/manager within the organisation?  That's the person to go to. Or hire an expert.
Sorry I can't advise you further.
Re: Linux Data
Re: Linux Data
« Reply #9 on: May 13, 2021, 02:02:38 pm »
There is one possibility.  But before I mention it you'll need to know how to start a Terminal Session.
Please read the instructions here https://linuxforums.org.uk/index.php?topic=14086.0, which you ought to have done as a new member.
