Author Topic: intel pentium gold 7505  (Read 200 times)
Offline jojo
« on: June 02, 2021, 04:11:20 pm »
Hi,
sorry, silly question but i don't see it listed anywhere.
is the "intel pentium gold 7505" processor supported by linux
Re: intel pentium gold 7505
« Reply #1 on: June 02, 2021, 04:39:56 pm »
Hi JoJo - and welcome to the forum.
Not sure what you mean by "not listed anywhere" - there are lots of references to it on the web.
As far as I can tell, the "intel pentium gold 7505" has PAE (Primary Address Extension) that allows it to address up to 64GB RAM, and this is a requirement for Linux to run.  So it looks OK for you.
The 7505 is a budget CPU so don't expect very fast performance.  Other than that it should be fine.
Offline jojo
« Reply #2 on: June 02, 2021, 04:42:36 pm »
ok thanks a lot
