Author Topic: HOW TO UNINSTALL FIREFOX ON UBUNTU AND OTHER SOFTWARE  (Read 195 times)
Offline Matilda
  • Gender: Female
« on: June 15, 2021, 10:02:58 pm »
Guys, i can figure out how to uninstall Firefox off my MacBook that is running I also want to get rid of some games such as Suduko ( my bro installed all this). I am used to Peppermint distro.
Got 2 Linux computers:
Peppermint on a netbook
Ubuntu on a Macbook Pro
Also got a Chromebook!
Offline SeZo
Re: HOW TO UNINSTALL FIREFOX ON UBUNTU AND OTHER SOFTWARE
« Reply #1 on: June 16, 2021, 10:20:22 am »
Assuming Firefox is installed the snap way (appears to be default in Ubuntu):
Check if it a snap package:
type firefox
if it says
firefox is /snap/bin/firefox
Then uninstall it:
sudo snap remove firefox
To complete remove folders associated with it:
sudo snap rm -r firefox
Offline Matilda
  • Gender: Female
« Reply #2 on: June 16, 2021, 04:53:54 pm »
I did that but it said it is not installed. It still is though as I just went to the software and launched it!
Offline SeZo
« Reply #3 on: June 16, 2021, 08:18:36 pm »
What was the output from:
type firefox
Was it
firefox is /usr/bin/firefox
If that is the case then it is not a snap package.
You should be able to remove with apt:
sudo apt-get --purge autoremove firefox
Offline Matilda
  • Gender: Female
« Reply #4 on: June 20, 2021, 06:37:30 pm »
Done thanks!
