Author Topic: My scanner doesn´t work on Ubuntu  (Read 4268 times)
Offline Matilda
  • Gender: Female
« on: June 16, 2021, 05:00:55 pm »
I plugged my old windows scanner into my MacBook running on Ubuntu and although the light on the scanner is on the Macbook says that it cannot connect to it.
There´s nothing wrong with the scanner as it works great on my Peppermint netbook. What could be the problem guys?
Got 2 Linux computers:
Peppermint on a netbook
Ubuntu on a Macbook Pro
Also got a Chromebook!
Offline Brian000
  • RAID is not backup
Re: My scanner doesn´t work on Ubuntu
« Reply #1 on: June 16, 2021, 09:15:35 pm »
Hi,
Could you kindly share some important details, like the make and model of the scanner.
...But, the light - that may just be power, which is not any confirmation of connectivity.
Offline Matilda
  • Gender: Female
« Reply #2 on: June 17, 2021, 12:24:23 pm »
Packard Bell Diamond 1200.
« Reply #3 on: June 17, 2021, 01:55:35 pm »
With the scanner plugged in try:
scanimage -L
and report the output.
Offline Brian000
Re: My scanner doesn?t work on Ubuntu
« Reply #4 on: June 17, 2021, 08:38:07 pm »
Based on this it's supported but looks to require some manual work
https://ubuntuforums.org/showthread.php?t=771976
Edit: adding URL for SANE
http://www.sane-project.org/cgi-bin/...model=&bus=usb
Offline Rich J
  • Still a Linux Luvvie!
« Reply #5 on: June 18, 2021, 06:20:48 am »
You might try this - https://forums.linuxmint.com/viewtopic.php?t=150579
Copy and paste the instructions, in turn, into terminal.
(found by googling your scanner model)
Rich
Offline emegra
« Reply #6 on: June 18, 2021, 09:13:28 am »
Hi Melissa
I had the same scanner Melissa with the same issue,
Your scanner needs a firmware file, placed in /usr/share/sane/gt68xx/, I have this file if you private message me your email address I'll send it to you and then help you place it in the right path, if you're not comfortable giving me your email address we'll find another way to pass the file on to you
Offline Matilda
  • Gender: Female
« Reply #7 on: June 19, 2021, 01:52:09 pm »
Hi Melissa
Thank you very much Graeme. I now remember that you had sent me firmware for my Peppermint netbook a couple of years ago. It works great on the netbook so I expect it'll do the trick for the Ubuntu MacBook too.
Offline emegra
« Reply #8 on: June 23, 2021, 03:01:33 pm »
When you're ready Matilda, place the file I sent you in your ~/Downloads folder then post here when it's done and we'll take it from there
Offline Matilda
  • Gender: Female
« Reply #9 on: June 26, 2021, 03:26:05 pm »
It's been sat there for a few days waiting for its instructions Mr. Emegra!
Offline emegra
« Reply #10 on: July 06, 2021, 07:14:25 pm »
Hi Matilda
Can you confirm you have the file I sent you in ~/Downloads ?
Offline Matilda
  • Gender: Female
« Reply #11 on: July 16, 2021, 06:55:17 pm »
Hi Matilda
Yes I did in the above message, written on June 26th!
« Last Edit: July 16, 2021, 06:57:08 pm by Matilda »
Offline emegra
« Reply #12 on: July 19, 2021, 05:24:09 pm »
Ok Matilda
copy & paste the following command into the terminal then post back the terminal output
sudo mkdir /usr/share/sane
Offline Matilda
  • Gender: Female
« Reply #13 on: July 30, 2021, 12:48:18 am »
[email protected]:~$ sudo mkdir /usr/share/sane
[sudo] password for avon:
mkdir: cannot create directory ‘/usr/share/sane’: File exists
Offline Matilda
  • Gender: Female
« Reply #14 on: July 30, 2021, 12:49:31 am »
scanimage -L
[email protected]:~$ scanimage -L
device `gt68xx:libusb:001:016' is a Mustek BearPaw 1200 CU flatbed scanner
