Updates:
Many new features now available including 2-Factor authentication
My scanner doesn´t work on Ubuntu
Started by Matilda, June 16, 2021, 05:00:55 PM
Previous topic - Next topic
Matilda
Quote from: Rich J on June 18, 2021, 06:20:48 AM
You might try this - https://forums.linuxmint.com/viewtopic.php?t=150579
Copy and paste the instructions, in turn, into terminal.
(found by googling your scanner model)
Rich
Started that, but got a scary response, so did not go any further.
[email protected]:~$ sudo apt-get install xsane
[sudo] password for avon:
Sorry, try again.
E: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 25667 (unattended-upgr)
N: Be aware that removing the lock file is not a solution and may break your system.
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
Using an Asus netbook running on Peppermint 9.
That's OK - the system was updating itself in the background so couldn't let you do anything with the system.
If you try again, it should be alright.
Matilda
No, it still doesn't work! It still says it is unable to connect to the scanner, so yet again I have to use my tiny Peppermint netbook, which takes ages to boot up, to scan documents..grrr--
Matilda
I'm not very impressed with Ubuntu as an OS to be honest. Peppermint is much better! I'll have to take this MacBook to the computer shop in the near future and ask them to get rid of Ubuntu and put the latest Peppermint distro on it.
emegra
Hi Matila
There's a few steps we have to go through I needed to know /usr/share/sane was on your system before we could proceed
please copy and paste into the terminal the following command
sudo mkdir /usr/share/sane/gt68xx
then let me know when you've done that
Matilda
Nothing much seemed to happen there Emegra!
[email protected]:~$ sudo mkdir /usr/share/sane/gt68xx
The command just created a directory.  You can check usingls /usr/share/sane/gt68xxEmegra will add file(s) later.
emegra
#22
That's ok, all we need to do now is place the file I sent you into that folder you just created and the set the permissions, so paste the following into the terminal
cp ~/Downloads/PS1Dfw.usb /usr/share/sane/gt68xx/
Then post output of
ls -l  /usr/share/sane/gt68xx
Matilda
Quote from: Keith on August 01, 2021, 06:33:48 PM
Ok. I have to admit I have no idea what a directory is unless I Google it. Do you think my brother put an old version of Ubuntu on this MacBook? It seems to be taking a lot of effort to load software unlike Peppermint. I had the same problem with Ubuntu with the little netbook my other brother gave me and then Mark Greaves (bless him) told me to post it to him, and he put Peppermint on it. He always used to say that laptops/netbooks work best with Peppermint.
Matilda
It still doesn't like it!
[email protected]:~$ cp ~/Downloads/PS1Dfw.usb /usr/share/sane/gt68xx/
cp: cannot create regular file '/usr/share/sane/gt68xx/PS1Dfw.usb': Permission denied
emegra
Ok that's my fault Matilda I'm sorry
try this
sudo cp ~/Downloads/PS1Dfw.usb /usr/share/sane/gt68xx/
Then
Then post the output
Matilda
Oh well, never mind guys. I will call the computer shop in town tomorrow and see how much they will charge me to wipe this Ubuntu off and put the latest Peppermint distro on this MacBook. This Ubuntu seems to have too many problems. My bro probably used an old version! I told him last time he put Ubuntu on a computer for me ( which was the netbook my other brother gave me, which Mark later on put Peppermint on) that he should only put Peppermint onto laptops and netbooks. Ubuntu doesn't seem suited to them.
Matilda
No idea if this is what you were hoping for, but here it is!
[email protected]:~$ sudo cp ~/Downloads/PS1Dfw.usb /usr/share/sane/gt68xx/
[email protected]:~$ ls -l  /usr/share/sane/gt68xx
total 8
-rw-r--r-- 1 root root 7256 Aug  1 18:47 PS1Dfw.usb
Matilda
You do know that the software is called document scanner on Ubuntu and not simple scanner as in Peppermint? It is not the same one.
emegra
Ok we're nearly there Matilda
now copy & paste the following command into the terminal
sudo chmod 744 /usr/share/sane/gt68xx/PS1Dfw.usb
then once again
sudo ls -l  /usr/share/sane/gt68xx
then post the output
