Author Topic: Installing dash-to-panel via Gnome  (Read 108 times)
Offline golcarjack
« on: June 18, 2021, 10:23:39 am »
I am Using Rocky 8 (based off Cent0S 8), and ,my GNOME is updated to the most recent version. I have been trying to install the "Dash-to-panel" extension (using Brave as my default browser), however when I try to use it in order to make changes, nothing happens, in addition to this the default settings aren't in effect either, essentially like it thinks I don't have it installed at all. It also does not show up on my extensions button in Brave either.
Re: Installing dash-to-panel via Gnome
« Reply #1 on: June 18, 2021, 04:11:13 pm »
Hi Golcarjack - and welcome to the Forum.
I note that there is a known bug in "Dash-to-panel".  You  might find this link helpful:
https://github.com/home-sweet-gnome/dash-to-panel/issues/1265#issuecomment-861987521
