Author Topic: Can't get Smartmontools <Solved>  (Read 1047 times)
Offline RATTLEBACK.131
« on: July 30, 2021, 04:49:48 pm »
Follow my recent escapades & while still have my 'computer head' on I thought I'd try & check the heath & age of my HDD. Searching I came across Smartmontools command but this had to be installed.
Followed the instruction : $ sudo apt install smartmontools
At the end of the install I had these err, messages:
Err:6 http://security.ubuntu.com/ubuntu bionic-updates/main amd64 libmysqlclient20 amd64 5.7.34-0ubuntu0.18.04.1
  404  Not Found [IP: 91.189.88.142 80]
Get:9 http://gb.archive.ubuntu.com/ubuntu bionic/universe amd64 mailutils amd64 1:3.4-1 [140 kB]
Get:10 http://gb.archive.ubuntu.com/ubuntu bionic-updates/main amd64 smartmontools amd64 6.5+svn4324-1ubuntu0.1 [477 kB]
Fetched 2,923 kB in 1s (3,736 kB/s)
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/m/mysql-5.7/libmysqlclient20_5.7.34-0ubuntu0.18.04.1_amd64.deb  404  Not Found [IP: 91.189.88.142 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I ran 'apt-update' then tried --fix-missing.   Update updated stuff, 'fix-missing' wasn't recognised.
More searching got me short tutorial on fixing broken/missing packages. did this :
:~$ sudo apt-get update --fix-missing
Hit:1 http://gb.archive.ubuntu.com/ubuntu bionic InRelease
Hit:2 http://gb.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:3 http://gb.archive.ubuntu.com/ubuntu bionic-backports InRelease
Hit:4 http://ppa.launchpad.net/micahflee/ppa/ubuntu bionic InRelease
Hit:5 http://security.ubuntu.com/ubuntu bionic-security InRelease
Reading package lists... Done
then:
$ sudo apt-get install -f
Building dependency tree
0 to upgrade, 0 to newly install, 0 to remove and 10 not to upgrade.
Then I was allegedly read to go so did this (with results):
$ mount | grep 'on / type'
/dev/sda2 on / type ext4 (rw,relatime,errors=remount-ro,data=ordered)
$ sudo smartctl --xall /dev/sda2
sudo: smartctl: command not found
so followed instructions to get rid of any broken/incomplete packages :
Hit:3 http://ppa.launchpad.net/micahflee/ppa/ubuntu bionic InRelease
Hit:4 http://gb.archive.ubuntu.com/ubuntu bionic-backports InRelease
$ sudo apt-get clean
$ sudo apt-get autoremove
& finally my question - am I ready to have another go at installing Smartmontools ?
« Last Edit: August 02, 2021, 11:31:25 am by RATTLEBACK.131 »
Offline SeZo
Re: Can't get Smartmontools
« Reply #1 on: July 30, 2021, 05:35:34 pm »
Always update before install  ;)
Try installing it again
sudo apt-get install smartmontools
then on a full disk (not partition)
sudo smartctl -a /dev/sda
« Reply #2 on: July 30, 2021, 06:46:31 pm »
Just tried the install command you gave & got this weird **** in a purple edge box replacing the terminal:
Package configuration
 --------------------------------------------- Postfix Configuration ---------------------------------------------
  | Please select the mail server configuration type that best meets your
  | needs.
  |  No configuration:
  |   Should be chosen to leave the current configuration unchanged.
  |  Internet site:
  |   Mail is sent and received directly using SMTP.
  |  Internet with smarthost:
  |   Mail is received directly using SMTP or by running a utility such
  |   as fetchmail. Outgoing mail is sent using a smarthost.
  |  Satellite system:
  |   All mail is sent to another machine, called a 'smarthost', for
  | delivery.
  |  Local only:
  |                                 <OK>
Can't get the terminal back, trying to close the window says there is still a process running in this terminal closing will kill it. Gonna kill it.
« Last Edit: July 30, 2021, 06:51:58 pm by RATTLEBACK.131 »
Offline SeZo
« Reply #3 on: July 30, 2021, 09:07:02 pm »
Well, you must have installed (or tried to) mailutils (postfix) which after forcing the fix-missing has come to the point of setting itself up  ::)
It appears that if you got install recommends set then smartmontools will pull in mailutils.
Remove the packages first:
sudo apt-get remove smartmontools
You can test this by:
sudo apt-get install -s smartmontools
To install without the extra packages use this:
sudo apt-get install --no-install-recommends smartmontools
« Last Edit: July 30, 2021, 09:29:45 pm by SeZo »
Offline Mad Penguin
« Reply #4 on: July 31, 2021, 12:03:00 pm »
Smartmontools includes a background daemon that will [optionally] periodically monitor your storage devices and attempt to report any problems it finds .. via email (!) .. so just be aware, if you opt not to install  some sort of basic email facility on your machine, you may not get notifications if impending doom should one of you drives start to fail ..  ;)
« Reply #5 on: July 31, 2021, 05:53:49 pm »
Successfully installed (without recommendations). Thank you (yet again) :)
Offline SeZo
« Reply #6 on: August 02, 2021, 10:39:27 am »
As Mad Penguin pointed out, it is a good idea, having a mailer running on your system to get notifications (by mail) of impending doom. So you may still want to install postfix.
If you are happy that all is well, please mark the title of your first post on this topic as [SOLVED].
« Reply #7 on: August 02, 2021, 11:30:52 am »
Thanks. I'll bare that in mind for future but as my HDD died yesterday it's a bit superfluous for the moment. I put a few more details of this on my other thread. Basically old age.
